97' 4Runner Limited 4wd 3.4/Auto/E-Locker - Northern VA
montana_jeepn
97' 4Runner LTD 4wd 3.4/Auto/E-Locker - $6250 - Rebuilt!
Sorry to see her go, but I have too many cars.
I am the second owner and just bought her in December and have been steadily working on her since then. I had intended to make her my DD, thus have spared no expense and have taken no shortcuts. I have receipts for everything if needed. Finally finished last month and have been driving her to work every day since then. I've put about 700 miles on the suspension and will be taking it in for another alignment prior to sale. VA inspection good though Dec. More pictures will be forthcoming. Located right outside of DC.
Here is the most recent picture I have:
IMG_9980_zps1b68a6c0.jpg~original
97' 4Runner Limited, 4WD, 3.4, Auto, E-Locker
Color: Desert Dune/Silver
Miles: Approx. 215k
MPG: 15 mix city/highway. (currently has P265/70r17's....price reduced $750 to reflect) She purrs at 70-75mph.
Title: Clean and in hand.
VIN: JT3HN87RXV0081074
Front Suspension
- New Bilstein 5100/OME 881
- New ADDCO 573 1.25" Front Sway Bar
- New Energy Suspension 9.5165R 1-1/4" Greasable Sway Bar Set
- New Mstudt Sway Bar Links
- (2) New Toyota Factory Lower Control Arms
- New Toyota Factory Cntrl Arm Cams/Bolts
- (2) New Toyota Factory Lower Ball Joints
- (2) New Light Racing Upper Control Arms
Rear Suspension
- New Bilstein 5100/OME 890
- New ADDCO 483 1" Rear Sway Bar
- New Energy Suspension 9.5161R 1" Greasable Sway Bar Set
- New Sonoran Steel Adj Panhard Bar
Brakes
- Tundra Brake Upgrade
- New Factory Toyota Tundra Rotors
- New Factory Toyota Pads
- New Reman. Eclipse Calipers (NAPA)
- New Braided Stainless Steel Brake Lines
- New Sonoran Steel Parking Brake Rear Axle Bracket
Exhaust
- New Magnaflow 18" stainless - welded
Engine
- New PVC
- New Silicone (blue) vaccum lines
- Recently cleaned TB
- New Toyota TPS
- New Idle Speed Control
- New Air Raid Intake
- New Koyo Radiator
- New OEM Radiator Hoses
- New Toyota Factory Spark Plugs
- New Toyota Factory Spark Plug Wires
- New Toyota Factory Fuel Filter
- New TRD TB gasket
- New Toyota Factory Air Filter
- New AutoCraft Platinum AGM Battery, Group Size 24F, 710 CCA
Misc
- New factory turn-signal stalk (w/ Fog light switch)
- Had rear License Plate bolts removed and re-tapped at dealer
- New Tacoma Whip Antenna Mod
- Deckplate Mod
- New Dash Clock
- Will come with a set of 17" Factory Toyota Rims (2005 Sport rims or 2011 SR5 rims) and an older set of P265/65/17's. If you really want the rims/tires that are on it (have $825 in the tires and around $400 in the rims) we can work something out.
Interior
- Tan Leather - Drivers is rough with tears
Exterior
- Body has the dings and scratches here and there, but overall in good shape.
- Frame is solid with only a little surface rust here and there. Original owner had undercoated it when it was new.
- Running board delete
Maintenance
- Oil just changed
- Rear Diff just changed
- Just checked the Tranny and Front Diff and they are good to go
- Flushed the power steering when I had the steering rack off
- Power flushed the brake system
- Prior owner told me the timing belt was done, but I have nothing to confirm this.
Please let me know if you have any questions.
Price: $6250
Folks. Am I in the ball park with my pricing? Everything has been installed within the past 4 months. Have receipts for everything. Just had her aligned yesterday since I've put about 1500 miles on suspension. Drives like a new truck.
For $7k I will include the new Firestone Destination tires and Clarion NX603 Nav/DVD and lastly my Scan Gauge II. Thanks.
Seems fair. Craigslist it too if you haven't already (I'm sure you have).
Thanks for your thoughts. I decided to use the Firestone tires on my 4th gen, so this is what she looks like now. I am going to try to take better pictures soon with my good camera. Maybe this weekend after I give her a bath. :)
New alignment last week since I now have about 1500 miles on the new suspension.
photo3_zps4a59dd94.jpg~original
photo2-2_zps748ca5c9.jpg~original
photo1-2_zpsbf1ff213.jpg~original
photo1-3_zps380885bc.jpg~original
Jhunt
