'97 and It's Fog Lights Are Out--Help!!
Big Fee
Hi Guys,
I'm a Newbie here but I have probably a dumb question to ask. My factory fog lights have just recently went out along with the lighted fod light switch on the dashboard. I'm guessing it's just a fuse, but which one is it? My owner's manual does not have any fuses labelled as to which one powers the fog lights. Does anyone know which fuse would be the correct one to replace and where it is located? Thanks alot in advance.
If it has a dash switch instead of the column then there is a chance that it was installed by the dealer or once it hit the mainland. This was true with my 98 t4r. If the fuse isnt in the panel then trace your wiring from the fogs back, my fuse was located along the driver's side fire wall in a small, black, water tight case. If it isnt a fuse then check you relay and all connections. Hope this helps.
