Hey guys and gals.
I currently own a:
97 Sr5 4Runner 4x4
Auto, 180K
-past maintanence - T-belt, waterpump, thermostate done @ 160k
1.) I was one my way home from a trip last weekend and when I tried to pass someone on the interstate it started to "hip cup" kinda felt like the transmission was slipping every couple seconds. Once at cruising speeds it would be fine until a hill then it would do it again, unless it down shifted then it would be fine at the higher rpm (3k or so).
*I checked the transmission fluid and it was full and didnt have any odd colors.
I would like to note that the 4runner runs/drives fine in town just likes to act up once in the last gear and driving around 50mph and up.
Any ideas on the issue? could it be the transmission? Spark plugs/packs/wires? TPS? other?
2.) I also would like to mention I had a misfire a couple months ago do to moisture getting inside the coil pack, so I was going to replace the plugs and a coil pack, but the previous onwer didnt put anti-seize on the plugs and they are stuck pretty good. Any ideas on how to get these out without breaking them? I put some PB blaster in the spark plug hole and let it soak for now.
thanks for the help.
I currently own a:
97 Sr5 4Runner 4x4
Auto, 180K
