98 4R Ltd. Replaced Belts -Nothing powers on
mmuribi
HELP. Only replaced belts. Now, Nothing (ALL Systems, Accessories and indicator LEDs) will power on.
Jump connection failed
Portable Starter failed
All fuses looks good
Bad connection at the battery, or you forgot to hook a ground wire back up somewhere. Probably the latter. Putting a set of cables on it should have at least lit up the interior lights.
Bad connection at the battery is usually what causes it. Often times you'll have corrosion built up between the terminals and not ever know it. Take the terminals off, clean them really good with a wire brush or similar, and you will be good to go. IF that doesn't fix it, you may have corroded battery cables, but I've never seen that happen in a 3rd gen. Not saying it can't. but 99% of the time its just the terminals.
Replacing the belts and having it happen right after is likely just an unfortunate coincidence.
wayblom
