Just tested the starter using jumper cables and is fine but we tested the ignition wire going to the starter and it isnt getting any ignition power to the starter. So im not sure what this means.. Could my aftermarket alarm system be screwing everything up? What else?
So you got engine to crank? Did you get it to start? How wet did you get this trk
When you ruined engine? Maybe some other electrical component has failed,time to get wiring diagram and start working thru it
Alarm circuit is always prime suspect.
Also:
30A AM2 fuse (this was cause on a recent engine swap I helped with. This is big fuse you can't check visually)
40A AM1 fuse (likewise)
EFI relay
Starter relay
10A IGN fuse
7.5A STA fuse
Circuit Opening relay
Key switch
Park/neutral switch
That's off the top of my head. There is probably more. Time to get in there and chase it down, double checking all those listed fuses first--with a light or meter, NOT visually--then checking voltage at key switch and starter relay after that.
Did you use your old wires of the old engine or the JDM wires ?
Bad relay?
Hey guys I drove through some questionably deep water about a year ago and threw a rod in my 240k mile 1998 5vzfe. For the last year we have been working on it and we bought a JDM engine with said to be low mileage. Put everything together and finally tried to start it last night and the relays all seemed to click but the starter made no noise at all. It is a brand new starter. Battery is good. All the grounds are where they are suppose to be. We can hear clicking coming from a relay near the battery and a relay on the passenger side. Could this be Neutral Safety Switch? If so how do you get to it and check and see if its good? What else could it be? Thanks in advance!
