98 Limited 4WD
italian.4runner
Good Evening y'all,
I just got my 98 4Runner and I tried to engage 4H IAW with manual, and I do not get any indications on the dash. I am able to engage 4L and I get the Green light on the dash. Any ideas on possible issues?
Thanks again,
I 4Runner
So you can engage 4Lo? If so, the difference between 4Lo and 4Hi is mechanical, if one engages so should the other. Followed the instructions under the driver visor?
Sometimes the 4wd light switch sticks. When this happens, the 4wd light on the dash will not kick on but yet the vehicle is in 4wd. My 1 4 runner does this from tome to time.
From what I gathered. It's fairly common and a replacement of the switch fixes it. :)
With yours being a limited, your actuator may stick as well. Which if fails will need replaced. Luckily they mostly just work.
seltzernator
