99 & 00 Limited Perks
Jidaran
I know the 99 and 00 Limiteds are highly desirable due to the fact that they only model to have both mutli-mode and the option of an e-locker. I seem to recall reading about some other advantages though (when compared to SR5 and the 01 and 02s), but I’m having trouble nailing down the facts. Here’s what I got so far:
99 Advantages
-Taller rear springs (though these are easy enough to replace)
99 & 00 Advantages
-No TRAC / VSC (though this is super easy to disable)
Limited Advantages
-Leather interior (though this is debatable since most driver’s seats are cracked)
-Larger brakes (though it’s not important if you plan on doing the TBU)
-Better sound system
Remaining Questions
-I remember reading that the 99 and 00 transfer cases are better than 01 or 02 since they’re mechanically actuated instead of push button. Any truth to this?
-I also remember reading that the older models are better as there are fewer electronics to break. I can’t find a list of what additional electronics were added after 99 though.
-I heard the 01 and 02 are more sluggish with the pick up, for some reason.
I think the front differential is vacuum ADD whereas the 01/02 is electrical. Not sure about the transfer case.
01/02 has an electric brake booster that is practically impossible to repair and expensive to replace. 99/00 is the old style.
The 01/02 transmissions can have problems, I hear.
99/00 still has lots of electronic controls though. It's the 96-98 that are mechanical which I prefer.
99 Advantages
99 & 00 Advantages
Limited Advantages
Remaining Questions
Yep tcase in 99-00’s are J-shifters w/ the multi mode button on side. This is the main reason I got a 2000 limited w/ locker. Last year of locker & j-shifter!
Edit: Another good thing about the 99+ models is the storage compartment in the cargo area is much larger. Also there are slots to store the back seat head rests on the seat when you fold the rear seats down.
Is there a mechanical advantage to the J shifter? Any other advantage? (other than the obvious fact that a shifter is more fun than a button.)
Sadly, the "left side" of the J-shift on the '99-'00 is NOT mechanical. It operates a switch, which then tells the transfer case shift motor to operate. It is basically a button you operate by moving the shifter down.
Brakes are the same on all 16" wheel trucks. The only 'smaller' brakes are on the 15" wheel 4Runners, which also had much smaller diameter tires. Most 4WD's had 16" wheels and all Limiteds do.
The taller springs are on all of the '99 4WD's, not just the Limiteds. They were already getting 'lower' by '00.
How about Limited weaknesses?
- Leather (cracking with age, hot in the summer, cold in the winter - at least it is easy-ish to clean)
- Electronic HVAC system is less reliable
-Charlie
-Charlie
So your saying when I shift to 4hi it’s an electrical switch but then shifting to 4lo is mechanical? Is that what you meant by “left side”?
No clue lol..
Yes. The "left side" as you shift down from 2wd position into 4hi is electrical. Moving the shifter over to the right and then up into 4lo is a mechanical operation. This can be evident by the occasional grinding of gears if the vehicle is not at a complete stop or not in Neutral/Park.
Don't forget the expensive, electronic master cylinder on 01-02 that costs your first born to replace when it fails
Also, the charcoal EGR canister on 01-02 is under the truck, in front of the rear axle/cross member and is easily flooded and compromised on trail
While considered a negative by some, I like the digital hvac controls, with the auto button. Having the outdoor temp option is fun as well. I agree with all previous points, especially the cupholders.
I haven't really had any luck with my auto a/c button working I thought about getting it fixed and then I found out my frame is rotted to hell. "Low" mileage engine and trans is for sale if anyone's interested (don't have enough posts to put up something on the classifieds) 166k limited
frankly the 99+ cup holders is the best thing. ;)
This guy knows priorities! I had to put cupholders in mine, that tray design stuck around for way too long.
I like my 98. Taller springs than any other year except 99, and manual controls for everything. No electronic systems to break here, including climate controls.
Addendum, it is important to note that the '99 was the beginning of the "fat lip" bumper. The '98 and earlier bumper In my opinion is better looking. However, I like having the option of AWD or 4x4, and the rear locker, so I am happy I got the 2000.
Laredotx
