99 4 runner no brakes
schar
Help i have no brakes at all put in a new booster and still no pressure is building holds fluid cant figuar out why there is no pressure
not sure about booster oem bleed brakes didnt think of caliper piston
So you did or did not bleed the brakes? I am not trying to be rude, but a comma or period here and there would help us understand you...
If the caliper were seized, wouldn't the rear brakes still work?
Also--
Did you replace the booster as an attempt to remedy the problem, or was this problem caused by replacing the booster?
If the latter, why did you replace the booster?
Cpn2mss
