'99 4Runner Front Bumper Lights Needed
Blanco
The signal light housings that sit in the bumper of my '99 are cracked and taking in tons of water. Once they dry out they completely fog up and look like crap. Looks like they're sealed units so will need a new set. Have seen some online but nobody seems to want to sell/ship to Canada : (
Can anyone point me in the direction of a source that sells/ships to Canada or is actually IN Canada? Would like to also get clear ones if possible along with some matching clear corners at the same time. Thanks!
signal.jpg~original
I replaced my passenger signal light from an ebay seller, new for $10.87 usd. Search ebay, and don't settle on the first one you find- unless you want to, because you'll probably find it less expensive from another seller.
if you end up keeping it, pull the bulb out bring it inside for a few days and let it dry completely out, then use some clear silicone epoxy and seal up the crack and call it good... just my .02
Try E-bay....either stock or Aftermarket....I found some clear aftermarket lenses for my 98 for Cheap...shipped to Canada!
