99, 4Runner P0171 code
Jheera_blade
Hi all, I got this code (P0171) recently and am trying to isolate the problem. The acceleration is quite poor right now.
This far, I have tried the following, but the code keeps reappearing:
- cleaned the MAF censors
- replaced the fuel filter
- tested the pressure from the fuel pump, it is normal
I also pinched/blocked the return pipe from the fuel regulator and test drove the truck and it seems to be running fine with return pipe blocked. Right now I am open to suggestions about what it could be.
Also, if there is a diagram of fuel/vacuum system that I anyone has access to, it would really help if I can see it (from Toyota manuals or otherwise).
make sure you have no vacuum leaks. Ive also had maf sensors that needed to be replaced. cleaning just didnt do the job. 90% of the 4runners that come in the shop for that code were maf related. good luck.
