99 bezel
Elgat007
Dose any have or can they put up a pic of the white plug on the back of the deforst switch I'm trying to finsh the bezel swap but I don't have the plug pin out location. So a pic would be most appreciated. Thanks in advance.
Would the back of an '01 work? If so, I can snap a pic. It wouldn't be for a few days though. I'm messing with some wiring when I get a little free time.
I'll do it tomorrow for you if I can. I wish I had seen this earlier since I just got done doing some work on the 4runner.
This should do the trick. If you are talking about the digital A/C control, and if by defrost switch you mean Air Mode Control in Toyota Speak, that part is designated A37 in the wiring manual.
Look for the A37 pinout here:
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/ewdtmc2/ewdtmpdf/ewdsourc/2002/024runne/connecto/connecto.pdf
Use the numbers on that pinout to get the wire colors for A37 off this diagram (go to bottom of page 214):
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/ewdtmc2/ewdtmpdf/ewdsourc/2002/024runne/systemci/056aac.pdf
This is assuming that your '97 and the 2001 setup on-line are the same. That may or may not be the case.
No that's not it. But thanks. The one I'm talking about gose on the back of the bezel. The one for the rear defroster.
D'Angelo
