99 injector replacement questions
Purrrrrrr. Vroom vroom. Ahhhhhhhhhhhhhhhh
Apparently, injector #5 was bad. I swapped the original #2 injector for it, took it for a long test drive, and she runs great. Now I suppose I will find out if FiveOmotorsport stands behind their product and replaces it.
This sure was a major learning experience for me. I'm not done yet, until I replace that injector with a rebuilt one, but at least I can drive it until then. Or maybe I should knock on wood.
The saga continues...
First, I will mention that I am very pleased about FiveOmotorsport standing behind their product. I shipped back the one defective injector. Within an hour of them receiving that injector, I received a tracking number for its replacement. Good on them.
After receiving the replacement today, I was almost done with the installation, and I discovered that I had damaged injector #1 while re-installing the original injector after swapping it out for the rebuilt FiveO one. I was having trouble getting the fuel rail to line up with the injectors. I used the fuel rail bolts to pull it down, and I noticed it took excessive force. Today I discovered what happened. By cranking down on the fuel rail bolts last time, the rail "popped" into place, subsequently boogering up the very top of injector #1. I am not taking any more chances with this abomination project, so I just had to order a FiveO injector to replace that one. My T4R will be down until it gets from CA to GA, but I paid for expedited shipping.
Once I get that injector and get it all back together, I expect to be able to give a good update that the job is completely done. BTW, it has been running just fine with the old injector #5, so I am certain that was the problem all along. Mistakes happen, and nobody and no company is perfect. But they stood behind their product and took care of me.
Hopefully, this is my final update. I received my replacement injector today, installed it, and it runs great. FiveOmotorsport did right by me, overall.
Today I discovered a trick that would have prevented me from buggering up injector #1, when I used too much force to get the misaligned fuel rail down onto the injectors previously. I didn't remove the banjo bolts, because while applying a buttload of force to the 17mm bolt, it wouldn't break loose. I didn't want to break the fuel rail itself that way, so I left the banjo bolt(s) on, and just muscled up the rail, which slightly bent the plumbing attached to the banjo bolts. It was me trying to "unbend" those that caused me to crank down on the fuel rail bolts while it wasn't aligned exactly over the injectors. I hope I described that adequately.
Today, I put a long wrench on the 17mm banjo bolt. That allowed me to muscle the fuel rail precisely, wiggling and checking that the injectors were aligned correctly with the fuel rail holes. Then I was able to spin the fuel rail bolts in by hand and a nutdriver, then tightening them properly with a socket. Instead of cranking down onto a misaligned injector and buggering up the top of it like I did previously.
She runs like a sewing machine now, and I am very relieved. Thanks again for the helpful advice above, and I hope others can learn from my mistakes.
A smart man learns from his mistakes. A really smart man learns from other's mistakes. :biggrin2:
