99+ Intermittent AC Head Unit Issues
bowrappyo
Hi. I seem to be having some intermittent AC head unit issues.
60% of the time it seems to work fine.
The other 40% it kind of just has a mind of it's own or just flashes. Like this:
<div style="width:100%;height:0;padding-bottom:56%;position:relative;"><iframe src="https://giphy.com/embed/h4YyLZUUB6cgZMWRiA" width="100%" height="100%" style="position:absolute" frameBorder="0" class="giphy-embed" allowFullScreen></iframe></div><p><a href="https://giphy.com/gifs/h4YyLZUUB6cgZMWRiA">via GIPHY</a></p>
Usually, I turn the truck off then into the on position if it works normally I start the truck. If it doesn't I do that a couple times and it seems to go back to normal.
My thought is it has to do with the pentameter and could use a bit of electrical engineering refresh. Not too sure.
Does anybody have any thoughts? If my assumption is true. Would anybody on the forum know where I could send it off to for a tune up? Happy to remove it and ship it off for a fix.
Check the connections on the back of the control. Disconnect them and click them back in place. The problem your having is different then the normal issues. You may need a new logic board if your issues persist. Contact the other poster from the Great White North as he really seems to have all the answers :blabla::canada::der:
Ok awesome will do thanks!
Tx470
