So We raised the Highlander to day. I didn't wright down the color codes or part numbers but here are a few pics and measurements Before front and rear measured 35 1/4" after front was 38" and rear was 39 3/4" remember that this is with very worn 265/70/16 tires.
So rears are 97 LC 7.5 or 8 wrap front coils
these give you great stink bug look
rear shocks are trek masters witch have a cool little plate factory welded to the front of them to reinforce the shock tube from rock rash.
The fronts are tundra billies Semi adjustable set on the bottom grove with toytec top spacer and OME 880 coils
and a finished pic a bit of rake but things might settle a bit and the fronts can always be removed and reset to a higher setting:bravo:
also installed toytec 1" diff drop kit the front set up gave him 2" more droop than the 99 tall boys.
Had a good time today. NOW lets get some tires on that thing and wheel it
eace:
Glad I could help out another fellow 4runner owner and his ride.
Almost forgot we also performed the constant power to the power outlets mod.
