A/C kicking off?? Knob light flashing??
Presta24
I have a 03 V8. A few times this year the ac has stopped blowing cold and the light on the knob flashes. Still blows but not cold. Turn it off and back on and it works. Any one else had this problem???
I did as well, do a search and you will find the problem will most likely be the relay located in the engine compartment fuse box. To test it you can try swapping if with the fog relay and see if that fixes your problem. From some mods I did I had a couple of relays laying around so I swapped mine with one of those and haven't had a problem since. I plan on eventually buying a couple of spares from here. Good luck.
Amazon.com: Four Seasons 35874 Standard Relay: Automotive
