A/C not cooling magnetic clutch issues? 2004 SR5
rebelbowtie
So I don't drive my 4Runner since I bought my Jeep, it's primarily my wife's vehicle and she told me the A/C was not cooling. I immediately assumed it was low on refrigerant, well I happen to have a quick fill bottle of 134a and hooked it up to the system. The problem is as soon as I started to add refrigerant the compressor kicked on hard and made the engine surge and then shut off, I took that as a bad sign and stopped filling and even bled a tiny bit of refrigerant out (into a proper refrigerant evaluator of course....).
Now I notice the A/C light blinks on the HVAC panel and the compressor is unresponsive, only the fan speed changes. Quick google search brings me of course here to T4R where I find a TSB about the magnetic clutch relay being bad. I pull out the relay and it visually seems fine, no way of testing it I swapped in a new relay and the problem still persist.
The old relay is back in and my A/C is still not cooling, it's starting to get hot here in Alabama, hoping someone can shed some light in this situation.
Do you have refrigerant gauges? I would start with getting a proper measure of the system (pressure should be roughly equal to outside temp when checked sitting and not turned on both high and low.) There might be a code stored for the HVAC system, but it will be a factory code rather than a OBDII more than likely. I would bust out the DVOM and start checking the circuit and if you feel confident enough to jump the relay and have the A/C kick on manually a couple short times to verify the clutch is operative & that the compressor cycles freely.
Do you have any other issues with the vehicle?
Yes I feel confident enough to do that, I have refrigerant gauges at work but not at my house. Also the PDF's aren't showing up but I am on tapatalk. I will try and load them in my browser and give them a look over.
Thank you for the reply, also no other issues with the vehicle
was thiws issue later esolved?..my ac is weak........blows out not so cold air..and only works best on lowest fan setting...at high fan settings...the air isnt cold
Jhunt
