A few 4th gen Questions I need help with...
Hey everybody so I've been on a mod spree for the past several months and am looking or some info on a few different things.
1) Does anyone know what percent window tint is needed in the front to match the rear windows? Was possibly looking to do that at some point
2) My current toyo tires are still in good shape but once they wear out I would like to go with a more aggressive tire tread. I would prefer to keep the size at a 265/65/r17 if possible. Any suggestions?
3) I am in the process of replacing all of my shocks as well as the sway bar end links both in the front and rear along with poly sway bar bushings for better handling. Does anyone have any other suggestions as far as suspension goes?
4)Has anyone successfully modded the 5th gen mirrors to fit a 4th gen (I know there are threads but didnt see anyone who cut them to fit)
5)Im considering doing the satoshi grill mod and had seen a premade mesh on ebay that would fit. Has anyone used one of those kits or did you just make one yourself?
6) what preventative maintenance should I do at 152000 miles? I have replaced all the fluids except radiator (still looks good) (differentials, transfer case, transmission, greased driveshaft, power steering fluid gonna do oil in the next 500 miles) am replacing the shocks, sway bar bushings and end links as well. new spark plugs, newer air filter, serpentine belt, alternator, idler pulleys, undercoated wheel wells, painted frame, replaced all vacuum lines and rubber gas lines, battery last year....
I think you all get the point I am just trying to see if there is anything else I might be missing that needs to be done.
Thanks!
pic for reference
:wow:
How did you get it so clean under the hood?
Looks brand new!
