A few electrical problems
provin1327
I am having a few problems with my 2000 4runner and I figured I'd hop on here for some help.
First is the door locks. It used to lock the doors when you turned the key on and unlock them when you turned it off, that stopped working. All the other door switches work fine for locking and unlocking the doors, as well as the key fob.
There is also a green ring of light around the ignition, that seems to have burnt out/stopped working. Is that a bulb?
Next, the green D on the dash has burnt out, I have done some research on this and it looks like I can pop the dash out and replace the bulb
Finally, the glass on the drivers side mirror has cracked. The housing is ok but the glass is toast. Any idea on where to get a replacement mirror?
Hmm I have no clue on any of your questions.
However, I have bought the glass from rockauto.com. It is a pain to put in though. You have to heat up the plastic housing with a hair dryer until it expands enough that you can slide the new mirror in.
On rock auto I am only seeing the whole mirror assembly, not just the glass, can you pop the glass out and put another one in, or do you have to replace the whole housing?
If you take the access panel off from below the steering wheel you can see the light that lights up the key hole. I'm not sure if its a common type of bulb.
The one in the dash, do you really need it? I didn't even know it was lighted, I guess mines been burned out for a long time.
The door lock when you turn off thing. I think the dealer programs that.
