Master Yoder
I changed th eoil on my 2002 SR5 4WD truck today. Everything seems fine but I had a few questions.
Is it OK to tighten the oilf filter by hand after replacing it, or do you want to use a wrench to get it tighter?
When you remove the filter is there any way to keep it from spilling oil all over the place? When I removed mine I dropped it :banana: so that didn't help but now when I park on a slight backward incline it drips the oil that got caught on the shield below the oil filter and oil pan, I know it will stop after a little while but it is annoying since I don't want oil on my drive way.
I put 6 quarts back in after the change, drove it around for about 10 minutes and then checked the level on a flat surface and it was barely on the dip stick. I read before that you have to let it sit a few minutes but does that apply after you drive it around a little bit too or just after the oil change?
