A very basic how-to: Removing the Intake Manifold
ShooterMcGavin
[MENTION=120071]mtbtim[/MENTION] and [MENTION=102606]infamousRNR[/MENTION] put together a great video, detailing all of the steps to take apart and repair the valve cover gaskets. I used their video to access the valve covers and then realized the extent of residue within the intake manifold. I decided to take the intake manifold off and scrub the passageways. This isn't a complete How-To, but I hope I can provide some insight that I discovered, in order to help others. I did it alone, so I could only take still shots.
To anyone else who has done this or with experience in this area, feel free to add your advice as well. I am far from the expert.
Follow the video by [MENTION=120071]mtbtim[/MENTION] and [MENTION=102606]infamousRNR[/MENTION] to take the upper and lower plenums off. Cover the intake manifold intake channels and then clean the top of the engine thoroughly, on both sides of the intake manifold and the heads (I didn't do this but it would have been very helpful). After that, take the valve covers off. That was the procedure I took, but it might be possible to remove the intake manifold without removing the valve covers; I don't know.
To [MENTION=120071]mtbtim[/MENTION] and [MENTION=102606]infamousRNR[/MENTION], if you would rather that I don't link directly to your Youtube video, please PM me and I will remove the link.
Valve Cover Gaskets How-To
With the valve covers removed, your 5VZ-FE will look something like this.
Drain the coolant by loosening the petcock at the bottom of the radiator. Don't fully remove the plug.
Remove the 6 bolts holding the fuel rails onto the intake manifold. Each bolt will have a black spacer under it.
Unplug the connections to the injectors.
After the fuel rail bolts have been removed, the fuel rails can be pulled upwards and separated from the injectors. The fuel rails will be held on by the friction of the O-rings on the top of the injectors. *Note* When the fuel rails separate from the injectors, gasoline will leak out of the fuel rail. Make sure to take the necessary precautions regarding ventilation, open flames, etc.
When the fuel rails have been separated from the injectors, the injectors can be pulled from the intake manifold. Pull and use a slight twisting motion, and they should come out easily.
Make sure the coolant is drained. Remove the hose clamp and separate the top radiator hose from the fitting on the intake manifold.
The plastic timing belt cover is held on by 6 bolts. Only 5 of them need to be removed for this job. The hardest one to reach is the lower bolt on the passenger side and that one can remain. With all other bolts removed, the cover can be pulled out of the way with enough space to pull the intake manifold out. This is also a great time to inspect the timing belt. Here, I am not ready to pull the intake manifold off, just showing that the plastic can be bent out of the way easily.
The intake manifold is being held to the heads with 8 bolts. These bolts are easily recognized by the torx head within the hex bolt.
After the 8 bolts are removed, the intake still has 4 nuts on studs holding the manifold on, one at each corner. Here, you can see the extension on the front passenger side nut. The other front bolt can be seen below and slightly to the right of the driver side fuel rail. Each nut will have a washer under it.
Also, in the below photo, a bracket is being held onto the intake manifold with 2 bolts. That bracket can be seen just below the driver side fuel rail and it needs to be removed.
In this photo, the ratchet extension is on the rear driver side nut.
In the center of this photo, you can see the passenger side stud with some rust on the base. That is the final of the 4 nuts.
One last nut holds the intake manifold in place. It is really hard to see in this photo, because of all the dirt. It is a nut that secures the fuel line onto the intake manifold, on the rear driver side of the manifold. I'm trying to point to it here.
In the below photo, you can see the stud where the fuel line nut was removed. To the left of my finger, you can see a vacuum fitting where I removed a vacuum line. Also seen in this photo, is a coolant hose in the center rear of the intake manifold. It is really tough to get pliers on that hose clamp. Follow the steps below, before removing it.
Set the shiny plastic loom in front of the firewall up and out of the way. Move the driver side injector wiring further to the driver side. After that vacuum line is removed from the rear of the intake manifold (mentioned above), you should be able to move both of the fuel rails over towards the driver side, above the driver side valves. At this point, the intake manifold can be lifted off the studs which hold it in place. It may take a little effort to break it free of the gaskets. Pull up on the rear stud in the manifold and the front coolant fitting. Once the manifold is moved away from the firewall, you can get pliers onto the hose clamp for the coolant line at the rear of the manifold. Take that clamp and hose off, and the intake manifold should be free to be removed.
Done :)
I hope this was descriptive enough to help some people out there. Let me know if there are any questions or places where I need to clarify.
Very cool! Thanks for sharing the write-up and photos for removing the intake manifold. And, [MENTION=102606]infamousRNR[/MENTION] have no problem with you providing a link to our YouTube video. We want people to find our video and get useful information from it.
And, please show us the pictures of what the manifold looks like after you're done cleaning it and let us know what you used to get all those deposits off.
Good DYI.
I just did this, but instead of removing the fuel rails I undid the fuel banjo bolt and removed the FPR from the back of the manifold.
Just for reference you do not have to remove the valve covers. You can remove the upper and lower plenum then the intake manifold with no issue.
does anyone have a part ID on the black spacers the bolts go into on a fuel rail? of course, one of mine broke and now the bolt won't go in... having trouble finding a new one. thanks.
I think it's this but make sure this fits my 2000 t4r 3.4l. I bought mine from toyotapartsdeal and they verify parts by vin
Toyota Part No.: 90561-08020
SPACER
Toyota 90561-08020 SPACER
Part Description Spacer, NO.1(For Delivery Pipe)
Comment
(FOR DELIVERY PIPE)
Require Quantity 4
I'm...not 100% sure that's accurate. I believe the inside lip of either valve cover blocks it slightly. You may be able to finagle the intake manifold off without removing the valve covers, but I don't think you can.
I know I had (chose?) to remove the valve covers to get my intake manifold off when I broke a fuel injector off and the tip fell into the valves a few years ago. That was a good day.
Sent from my VS986 using Tapatalk
Kind of hard to tell in this picture, but here's my intake manifold off, and valve covers still on. This was right before I pulled the original 3.4 for replacement when I hydrolocked it offroad.
You can definitely remove the manifold without removing the cam covers.
Also, depending what you're working on you don't have to remove the fuel rail, you can disconnect the fuel line at the union on the LH of the engine with less fuss.
I did my injectors over the past weekend and you dont have to split the plenums to remove them. They can be removed as one unit. Just a heads up for those getting ready to attempt this job
Another note: if you take injectors out you have to replace the the o-rings. They are formed to fit over time and if they don't go in exactly how they came out, pretty much impossible, there's a high chance of developing a fuel/vacuum leak at the injector. If you leave them in the fuel rails, you don't have to change that one.
Part store o-rings work fine.
good point. My new injectors came with new o rings. And make sure you use a little bit of oil on the o-rings before re-installing. It would suck to rip or tear one.
I didnt undo the fuel lines/banjo fittings either since I was replacing all of them, I just lifted both rails up enough to get the injectors off.
I have a 94 4runner V6 3.0. I removed the Air intake, and after I put it all back together, I broke the fuel line about a foot away from where it bolts into the air intake manifold. Also, I am having a very hard time remembering where each of the hoses on the left go. The fuel line that goes to the air intake, where is it coming from? I don't know why I am not able to insert the picture here.... This is actually my first time posting a question on a forum, ever. But here is the link to the picture of the fuel line. PLEASE HELP!!!!!
url]
I know this is an old thread but I just wanted to make sure that I have everything to fix the leaky valve cover on my 2000 t4r sr5.
-Already have
--PCV (Toyota part #12204-62010)
--Grommet for PCV (Toyota part #90480-18001)
--Valve Cover Gaskets, two needed (Toyota part #11213-62020)
--Spark Plug Tube Gaskets, six needed (Toyota part #11193-16010)
--Washer Seals for the valve cover bolts, 16 needed (Toyota part #90210-05007)
--FIPG (Toyota part #00295-00103)
-Need to buy
--Intake Plenum Gaskets, two needed (Toyota part #17176-62040)
--Camshaft housing plug, two needed (Toyota part #11188-62010)
--Fuel Pipe washers, four needed (Toyota part #90430-12026)
--1/2 moon, maybe able to reuse (Toyota part #11183-62010)
My only issue here is I break a fuel line, as I heard they are fragile. Does anyone know the part numbers for the fuel rails??
-Already have
-Need to buy
Why are you disconnecting the fuel rail connections when you're just doing the valve cover gaskets? You commented on an intake manifold swap thread so maybe that's why you seem confused on the necessary parts for this job.
Sorry if I was not clear. I watch timmy the toolman youtube and he was saying that they are fragile and might break when changing out the injectors.
Gotcha. You didn't mention in your post that you're also tackling swapping out injectors too. By the way, I'm Timmy the Toolman. I don't remember saying the fuel rails are fragile though but maybe I did. I doubt you'd break one of the fuel rails doing this job.
