About time for wheels/tires..
digi
03' SR5 V8, size 265 / 65 / R17
Wheels are chipped up pretty bad so I mind as well do this all at once.
What do you guys recommend, Craigslist for factory wheels then head to les schwab or something?
If you are talking about USED tires...I wouldn't trust Craigslist.
I have purchased used tires from a local tire shop...
but only because I was broke, and because I had a business that I could return to if there was something wrong with them.
But your search is like buying ANYTHING.
Shop for the best price on what you want.
I like steel wheels, you could try Steel Wheels Buying Guide | eBay for those, got them for 05 Matrix plus Craigslist snow-tires, $50 per rim(new) and $100 for all 4 tires(like new). $300 + free mount and balance total. That's what I'm going to look for price wise, comparatively speaking. (Not driving the 4Runner in the snow(salt), garaged for the winter.) I think I did look up steel wheels and the price was $63 each on eBay.
http://www.toyota-4runner.org/rocka...code-parts-more-expires-january-3-2018-a.html has some 17" steel wheel too, if I remember correctly.
Another thing about tires, look around at what others are driving, I've seen some Michelin's I really like, but I want a street tire for summer, expecting not to do any serious off-road.
Currently I received nearly new Big-O Bigfoot's that are slightly oversized 265-75-16, not my preference, but will likely run them till a well priced budget set lines up. My buddy really likes the look, but I fear for early wheel bearing failure.
I'm pretty close to pulling the trigger on the trd wheels ($185 ea) from the dealer.
The current tire size on my runner is 265/65/17. I'm mostly highway miles but occasionally hit some dirt roads when I'm hunting. I'm trying to figure out if I should stick with a highway tire or move up to an all terrain tire? Should I stick with 265/65/17 or bump up to a 265/70/17?
Thanks for the help.
I have 265/65/17 on there now (03' SR5 4X4, v8), will 265/70/17's rub? Should I stick with 265/65/17's? Think Imma go with BFG KO2's..
I went with the FN fX TRD pro wheel and love them, $760 shipped. Before the lift I had Nitto Terra Grappler G2's 265/70/17 and no rubbing issues whatsoever.
Hankook Dynapro ATM's have pretty decent tread. Good road manners on the highway and are capable on dirt and mud. I found them better in the rain and snow than my KO2's, so I stuck with them when I bought a new set of tires this year.
Rims are entirely your personal preference. I like the TRD Pro rims, but there are a lot of good aftermarket options. I went with the Level 8 MK6 with a -10 backspacing. Fit better than my stock 5 spokes with 1.25" spacers did.
Thanks for the info.
80% of my driving is highway until I go hunting on the weekend, then its gravel/mud roads (nothing crazy). Think I should go with a trail tire or an all terrain?
Here she is, all done:
BFG AT KO2s 265/70/17 w/ TRD Pro 17" Graphite wheels. They slightly rubbed when turned all the way so I removed the front mud flaps and pulled the wheel lining forward, easy fix. I need to get some wheel locks for these TRD wheels, any recommendations?
Talyn
