ABS Beep
T4R916
Just got new tires a few days ago. 285/70/17 falken wildpeak and also alignment. Today when i made a U-Turn, it made the abs beeping sound as if i was losing traction. Any ideas why it happened? Tires are not rubbing btw.
Are you sure you didn't rub?? I've noticed mine will beep if im turning really sharp and hitting a bump. It's because my tire is catching on the body mount and that little momentary skip of traction is causing the abs to activate for just a half second. Has only happened to me like twice though
Just to be clear, I really never rub either its just when Im turning sharply and hit a big enough bump to cause the suspension to depress quite a bit in the front
I didnt feel it rub but i could be wrong. Maybe i'll try performing the zero point calibration and see if that will help.
This happens to me too sometimes, beeps and wheel shakes for a second. Mine only seems to do it when I am turning right at slow speeds. Hadn't thought of body mount rub.
are you sure it isnt the traction/skid control beeping, and you think its the abs. mine beeps on uneven roads, when the wheels are slipping or in the air for 2 or 3 secs.
observe your dash when next the beep happens, and see which of the dash lights would be illuminated
Jhunt
