ABS light comes on
ruinit3
My ABS light comes on whenever I turn my headlights on. If my headlights are off the ABS light is off. Any suggestions?
I recently changed out my brake lights to LEDs and reverse lights to LEDs and some interior lights to LEDs but didn't that was the problem.
I am going to unhook the battery and reset the ECU to see if that works but any other suggestions?
my abs and other lights turn on when i leave my subs on blast for a few hrs. which kills my batteries, but once both my battery are charged it turns off.:confused:
I unhooked the battery and reset everything and the ABS light STILL comes on when I turn my headlights on. Anyone have this problem!?
ABS light will get triggered when there is low voltage or something causing a big drain. In the case of LEDS they usually pull less power that regular bulbs. If you just did the LED conversion and the ABS light came on at the same time that must be the culprit.
if LEDs pull less power I don't know why that would get triggered since regular bulbs were in there before and I had no problem. I will switch the bulbs back and check the problem again.
I'll keep you posted. Thanks.
do you have any pictures of your new LEDS?
