ABS & Speed Sensor Line with Extended Travel
ebg18t
So now that i have extended travel Fox with DSM UniBall UCA's my travel is more than it was before. It appears i may have damaged by abs line/speed sensor line due to the travel. I attached them to the UCA like the OEM UCA did as the UCA was tapped for them. But it appears when the extended the line is ultra tight, i.e. pulling. What have the rest of ya'll done with your ABS and speed sensor wires?
You could see if you can create a wiring harness extension, it shouldn't be too much trouble. If you really wanted to go all out you could probably even get new connectors, pins, and such from online.
charlesz
