ABS system malfunction?
kball
Took a day trip to Sequoia Nat. park yesterday with the fam and decided while there to try out the abs in the snow. I don't drive on slippery surfaces too often in So. Cal. so I took advantage to try the abs and see what everyone complains about.
Everyone is right the abs systems on these suck! After making it activate a couple times though the brakes stuck. I tried to go backward in reverse and the truck wouldn't move. Going forward it would move a little but felt like I was dragging the rear end. I'm pretty sure the rear brakes were locked up.
I tried hitting the brake peddle and it was rock hard, wouldn't budge. I thought maybe the cold weather/snow possibly locked up the bell cranks but that wouldn't make the peddle hard. Also the parking brake felt normal.
So I just started driving slowly and after a hundred feet or so the brakes loosened. Then after another 100 feet they seemed to release completely again. I did not have any trouble with the brakes the rest of the day after that and I did not activate the abs either.
Doing a google search I found a BMW forum post and a guy was describing the exact same thing. I think possibly a valve in the abs module stuck and kept the brakes locked up..? What do you think?
I think it's time to snip that wire and disable abs permanently.
Exact same thing happened in my Ford, I ended up pulling the abs fuse and it unlocked everything, had to replace the module if I remember right, but it's been quite a few years since that happened.
I have a similar issue, on slippery surfaces (I.E. gravel, slippery roads) my brakes will lock up when braking under 2mph or so. Then when I try and accelerate I get the same dragging feeling you described except mine is the front right brake. I'm thinking of snipping my ABS wire as well just to see if that fixes it.
Tx470
