ABS-TRC-VSC control module 89540-35260 swap
khara
A while back my speedo died, CEL, VSC off, VTC off, ABS and e-brake warning lights were all on. I did some digging and found that most fixed this issue with replacing the ABS-TRC-VSC control module 89540-35270.
When I went to look at mine to check the p/n, I found that mine said 89540-35260. Also found someone on here saying that it was for the vehicles with 15in wheel options. I bought the truck off someone with 16s.
My question is, if I order the 89540-35270 off ebay and swap it with the 35260, will it be detrimental or is it just plug and play and for the most part I would be ok?
Update for anyone who needs it: Swapped it today with 89540-35270. I cleared everything with my code reader and it seems to be working. Cost me $140 from ebay instead of $2500 that I was quoted from a mechanic and the dealership. Thank god.
Hello, I know this was a while back, but how is the new module working out for you? Did you notice anything different after using it for a while?
Thanks!
