Absolutely Puzzled
mr280zxt
Hi,
I have a 1999 T4R Limited I just bought couple of weeks ago...
Clock was not working...So, I went to local junk yard and picked up a clock from 97......I started to remove the wood looking dash pieces to get to clock, so I can replace it...I found out clock had no harness connected to it...I look everywhere for the clock harness but no luck...Everything looks original, so I don't think anyone went in there with the sole purpose of cutting off the clock harness.
Any idea whats happening here?...
Thanks in advance...
Standard answer #17: Your harness is plugged into the wrong hole in the fascia. For reasons known only to inscrutable Toyota engineers, there is a second useless blind receptacle that accepts the clock harness plug. If memory serves, it's below the clock about a foot and towards the steering wheel. Pull that out and plug it in to your clock. You are not the first, and won't be the last.
Welcome to the forum!
I did the same thing while installing my Eclipse 5435...
I KNEW that I plugged everything in, but no clock. Tore it apart again thinking I must have missed a harness to go in the clock plug. Yeah, I felt dumb.
What is that for...?
The one I got from Junkyard, I got it without testing....They told me I can bring it back if it doesn't work...We have a another 2000 4runner limited in the family...So I have a spare clock for either of these T4R
They go for $60-$70 on eBay--but I'd save it for the 2000. They have a very high mortality rate. There is a fix if you are good with a soldering iron.
I actually am good with soldering iron...:)....and, I work around profesionals who use soldering iron for living. Where can I find the instructions?
No...Unless the one I got from junk yard is broken....Thanks for the link...I will save the instructions...Hopefully I will not need it.....
Do you happen to have any link how to remove gauge cluster as well.? My "D" drive light is out...I would like to change it...
mad props to The Durk
Is this a great place to hang out or what?
"The Durk" does it again.
can't answer your question mr280zxt but honestly a Google search sometimes works wonders as opposed to searching this forum or also consider YOTATECH.
