AC compressor kicks on and off
black4vcobra
After buying my 2006 4Runner this winter, I tried the AC for the first time about a month ago and I realized it was blowing cold on the passenger side and warm on the driver's side. I recharged it with a bottle of R134a and it blew cold on both sides.
Recently, I realized that the AC compressor keeps kicking on/off so the vents will alternate blowing cold/warm air. After researching it a little, I found that this is a fairly common problem with the magnetic clutch relay, (same part number used for fog light relay) Here is a thread from another forum that addresses it 2003 4Runner Air Conditioning issues... - Toyota 120 Platforms Forum
So I started looking around for relays and some guys are saying that the EVERCO 35874 from Autozone works, but it doesn't match up on the Autozone website. Autozone says this is the fog light relay Relay - Fog Lamp | 2006 Toyota 4 Runner 4WD 8 Cylinders T 4.7L EFI DOHC | AutoZone.com but they don't list an AC compressor relay.
Amazon says this Four Seasons 35874 Standard Relay Amazon.com: Four Seasons 35874 Standard Relay: Automotive works for slightly older 4Runners, but not for 2006s.
Amazon says this Standard Products ry345 fits my 4Runner, it appears to have an additional prong unlike the above relays. http://www.amazon.com/Standard-Moto...F8&qid=1401463239&sr=8-1&keywords=ry345+relay
If I can, I'd like to avoid dropping $70+ to get the part from a dealer, can anyone clear up if any of the above relays would work for my 4Runner? Thanks
I sourced my replacement magnetic clutch relay on eBay.
Just type in the part number (90987-02028) in the eBay search and you'll find some.
My Canadian Toyota dealership wanted way too much money for it up here, so I bought a brand new Toyota oem sealed in original packaging relay from a U.S. eBay seller for much less (even with cross-border shipping).
The relay has worked great ever since. :)
I was at work yesterday with my Mustang when I started the thread but I got home and verified that the relay in the 4Runner was the part number you referenced above. It is a 4 prong relay.
I bought 3 of these and they work for all, fog lights, AC, dome lights, etc.
AIRTEX / WELLS Part # 1R1696
Thanks, I will probably buy a couple as spares at that price. The picture shows similar prongs as what is installed.
Have you pulled the relay and swapped it with the fog lights to verify that will fix the issue?
Didn't swap but I did lightly tap the relay on the garage floor and when I reinstalled, the AC compressor stayed on like it's supposed to. From my research, the relay in my 4Runner was the "improved" relay that was called for in the earlier TSB but it still seems to be on it's way out.
Thanks for the help guys.
Jhunt
