No power to ac compressor
blue-r6
I have 06 4runner 4wd sport 4.7l. My evaporator core was leaking so I had someone replace it. After I get it back I pulled vacuum and it held air so I started adding refrigerant but the compressor never kicked on. I ran a jumper wire straight to the compressor and the clutch started turning and it got cold. I checked and I have no power to the compressor or the pressure sensor. I checked the fuse and swapped the relay with the fog light relay but it still didn't work. My front right high beam headlight, running light and rear defrost light does not work. I swapped the bulbs but still did not come on. I have no power to them. I also have a cel with vsc, trac and and traction light on. My codes are p1613 and p2445. All of this worked prior. I'm assuming he pinched some wires. What do you think?
erinobr2000
