AC Condenser Replacement
chris2879
I posted last week about a leaky AC Condenser Dryer plug. When i called the dealer about this they said the entire condenser has to be replaced because Toyota does not sell just the dryer portion of the condenser. I see online you can get the condenser dryer kit for $15, which is much better than $100.84 that the dealer told me the new condenser will cost. Curious me wants to know what i am getting into before i drop the truck off asked how many hours the condenser replacement would be, they said 3 hrs @ $104/hr. How hard is it to get the condenser out, it seems like 4 bolts and it drops out the bottom, am i missing something?
How hard are these to replace? Also, should I just buy the $15 denso condenser dryer kit and just put that in and take it to them for evacuation and recharge? Furthermore, if i were to do this, how do i depressurize the system before changing the plug?
I am just not sure the track i want to take, and am really not feeling 300 bucks in labor.
Here is the link to my other post with a picture.
http://www.toyota-4runner.org/4th-gen-t4rs/117998-fluid-leaking.html
Go to autozone and order one yourself. i had a rock hit mine and had to buy a new one. they are around 130 bucks. This price is for the entire unit. yes, 4 bolts and it drops out the bottom. I think i paid toyota here in phoenix az around 80 for the recharge/refill whatever its called.
Amazon Part Finder: Slide Show Results
good luck
I am not sure if you can replace the cap/white piece on the unit. I would research that a little more if you are trying to save money. either way you have to recharge it. i would be a little leery of popping a new "cork" on the end of it because the system is pressurized but that just me.
It's not hard to do either. When it's time to charge it up, don't bother going to the dealer. Find a local body shop (they usually charge up a/c systems multiple times a day) and save a ton of money. If you don't feel like tackling it yourself, they can do it on the cheap as well.
I just went to the dealer to diagnose the issue of hot air on driver side and cold air on passenger side. They stated that there​ is a leak in the condenser and needs to be replaced. They quoted me $900 to replace this but comparing it to your quote from the dealer and
the price of the CONDENSER ASSEMBLY - TOYOTA (88461-60091) I do not see how the dealer came up with that number.
all very good advice here, pretty much nothing to add to it other then be careful breaking fittings loose. only use 2 wrenches of the right size because the fittings are all aluminum with o-ring seals and its easy to bend or deform the nuts
Im late to the party, but if anyone has done this... a few questions.
1. Did you have the system drained before removing this?
2. Did you replace the seals/rings?
3. Which brand did you buy, Denso?
4. Did it help after the freon refill?
I have a pretty clear leak and seeing it light up with the dye they placed last year near the driver side ac hose where it meets the condenser. Also a darker "oil spot" on the condenser.
1. Yes, at an A/C shop.
2. Yes, smart to do.
3. Denso from Rock Auto
4. Yes
