AC Has musty smell
geedubcpa
My 2005 4runner has a musty smell coming out of the AC - I have used some AC cleaner but still get a faint smell. Anyone else with this problem?
Might just be the condensation build up from when you used it last, my GMC truck used to do that when I had my AC on for a long period
Yea, in cabin filter.. When did u change it last? Change my in cabin filter, air filter, and oil once a year Amsoil
Drain tube
Make sure the drain tube is not clog,find the drain tube and run a small wire to see if anything comes out.water must be collecting inside the housing and not draining when it should.
This! If you find the drain tube clogged then that could be your problem. If you can pull off the bottom of the a/c unit I would pop it off and clean it out with some bleach.
drain plug?
Where do i find the AC drain tube - also I have changed the filter and cleaned out the ducts with ac cleaner.
gw
wwarren702
