This is a pic of the gauges low and high side pressure readings while the truck is idling. The low side is a little high but probably within the specs that are 36.25 PSI . THe high side is supposed to be max at 227 PSI and you can see that it is around 270 PSI. I don't know alot about AC systems. Can someone tell me if the unit is overcharged or what is happening with this ? The outside temp was about 83 degrees at the time. THe air blowing out the vents on the dash is cool, but not COLD like other 4Runners I have owned.
This is a 1998 Limited Auto with 3.4L.
TIA
TIA
