Alpacamarc
I have a '98 V6 5-speed, under load & full throttle it misses and feel like it's not firing on all cylinders (low on power as a result). This happens between 1k rpm and 2k rpm when at low speeds and in 3-4-5 gears (let's say you didn't feel like down shifting and just went WOT) it bucks pretty good then. It then always accelerates normally between 2k - 3k rpm, then at 3k it starts up again... not bucking like at the lower rpm range but rough (intermittently at first) and low on power. I had a mechanic drive it (my father-in-law) and he said it feels like it's not getting the fuel it needs. I have the receipts from the previous owner's attempts at chasing this gremlin, he recently replaced the following:
-spark plugs
-spark plug wires
-fuel pump
-fuel filter
-injectors (I think? Can't remember)
Anyhow, he was unsuccessful at fixing it and now I'd like to figure this out. Does anybody have any ideas? My next step is to buy a new (or working) coil and do a trial & error on the 3 coils to see if one of them is the culprit. If that doesn't do it then what... maybe a crank position sensor or some other sensor (??). After that I don't know... maybe valve-train (sticking valve, etc. ?). Thanks for any help guys.
,Marc
-spark plugs
-spark plug wires
-fuel pump
-fuel filter
,Marc
