Add trans cooler for towing? 2002 2WD
Lee in Texas
I just bought a light duty trailer. Aluminum construction, 5'4"x10' cargo area. One ton capacity. Do I need to add a trans cooler?
It never hurts when towing to add an extra cooler, run it in series with the stock cooler in the radiator. Also, if you haven't replaced your radiator in the last 7 or 8 years (or just want to be super cautious) I would replace the radiator if your rig is an auto because of the potential pink milk shake if the radiator fails.
Since you have a 2002, you can monitor your tranny temps via a bluetooth OBD2 reader and the torque app (android phone). Or install a scan gauge. Once you can monitor your tranny temps, if it often goes above 200 degrees while towing, I would add the extra cooler.
I installed a tranny temp gauge in my 97 since it doesn't have one from the factory. I will be towing with it this summer and will install an extra cooler if need be. For now, any towing I have done has been in the winter in Wisconsin so it hasn't got past maybe 170 degrees.
I agree with thegipper. Adding a tranny cooler is never a bad idea. An external cooler will help with tranny temps better and you can bypass the factory in-radiator cooler which can leak over time causing a cooling milkshake.
Oh and since you're in the ausitn area, when towing at least and climbing some of our bigger hills turn OD off, that REALLY helps drop trans temps by 15-25 degrees especially during our lovely 100+ days. Luck and enjoy the runner. :cowboy:
Mike Sargent
