Adding a/c
1974RUNNER
So what all is involved in adding a/c to my 1st gen. Did not come with it, the wife wants it, soooooo. Do I need to find a donor or is there an all inclusive kit available? Should all the connections and bolt holes be there? Do I have to pull the dash? Thanks for the input. And more importantly the wife thanks anyone for the input.
Here's my story: Wanted to add it to my '86 which did not have a/c from factory. I got what I thought was all the parts and it always ended up being "one more part". There is an elusive pigtail connector that hooks up under the glove box. Make sure you've got that and they change the shape for that sucker every few years (not all 1st gens the same).
The other tricky part is that the compressor bracket mounts through one of the bolts on the timing chain cover. Do you want to pull a bolt out of that perfectly sealed cover? May be fine, may not.
Next is the true pain: Supposing you also got the button (a/c) and sliders from your donor car, you think you're good to go. Not so. The duct work underneath is totally different in one that has a/c versus one that doesn't. So yep, either tap into your inner Plastic Man, or pull that dash and reroute everything. Very little online info about this.
Conclusion: I spent a ton of $ and have all of the required parts (compressor, pigtails, o-ring conversion kit, condensor, duct work, button, control panel, etc., etc.) And it sits in a box in my shop. Has for over a year.
I so dreaded this job that I've decided I don't need a/c.....and I live in TEXAS! I'm not afraid of turning wrenches either, I've done a full rebuild on this 22re and do all of my own mods and maintenance.
If I haven't scared you away, I know a place where you can get all the parts......
MMMM........ Thanks TXCLIMBER. That sounds like a headache. Not what the wife wants to hear. I'm gonna have to think on this.
HAHA 9494runner!!! But seriously when its 115 and your driving 70 mph on I5 the wife would like it a little cooler.
Terry87 on Yotatech put junkyard A/C parts in one of his a while ago. 1st gens were set up at the factory to add a kit at the dealer. Everyone claims it's straight forward. This company used to list an aftermarket kit. Now you can contact them to assemble a kit. It used to cost about $1000:
Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment
If you go to google and search "add a/c Toyota 22RE" you come up with lots of threads. There used to be a great how to thread on Toyotaminis. There are tons of Toyota forums.
There is always someone selling an a/c system on eBay. You have to replace the O rings and drier:
Toyota Pickup Truck 4Runner AC A C Air Conditioner System 1984 1988 1989 84 88 X | eBay
Ac
I added one years ago wasn't to bad. The three holes in firewall already have a dimple for location. Just try and get all parts from same year and options as yours because was several different wiring harness and ac cards used.
I had mine installed in my truck way back in '91, it was around 800 when I had it installed at a local a/c shop in Honolulu. That was for a complete kit and installation in a non-a/c '87 SR5 Xtra cab.
Have you contacted some of the local a/c shops in your area to see what they would charge to install a/c in your 4R?
And just an fyi, I STILL have the same system in my truck after all these years, it still gets super-cold, and has the same original Sanden compressor that was installed. I thought the kit would have died by now, but, aside from a burst line from wheelin', its given zero problems whatsoever!
Ambrose67
