Additional Parts to replace while changing LCA
Mullett757
Hey all, I just ordered new LCA since my bushings are shot and was wondering what yall would recommend changing while everything is apart? I have new shocks and springs, Cvs and wheel bearings put in 4 months ago also.
2004 v6 sr5 w/ 129k
Thanks!
Are you replacing the CAM bolts as well? Other than that, I'd say the inner and outer tie rod ends, and only thing left is the upper control arms which you probably want to do if you're running more than 2.5" front end lift anyways. You'll pretty much have a whole new front end!!!
yeah I was thinking about those. actually didn't need new uca after my 3in lift thank god. I ordered new cam bolts too. right now its $300 to install the new arms and bolts and $79 for the alignment (im supplying parts)
utkrstam
