ADH8796 4runner Build
What are you putting on instead?
Ordered a set of 37x12.50r17 BFG KM2's
Hi there I was wondering how much you spent all together, coil overs,axle plus parts including metals for fabricating. I like to run a setup like yours
I don't know the exact amount. For this setup built yourself your looking at $5k-$10k depending on what you can find for what deals. I believe I'm in mine somewhere between $6k-8k but I got a lot of stuff for cheap. Like the front axle I bought came with cromos inner and outer, electric locker and radius arms already on it for $550. I was able to keep the cromo inners and radius arms but sold everything else. It really varies from build to build unless you buy a kit like trail gear.
I applaud your fab skills and clean builds. This thing is unreal. :wow:
Thanks man I'm glad to know a few people like what I've done with it. Hopefully I'll update some stuff soon.
Nice, are you concerned about the rear end holding up? That is my concern, even though I think it will handle the stress okay...but generally the E-locker is regarded as safe up to 35" tires.
The KM2's do run small though, which is why I think I (we) can get away with them.
Honestly I'm not too worried about the rear axle holding up. I think overall the ARB and gear set should be fine. The axle shafts are the only thing of real concern and I have an extra just in case. And like you said the BFG's tend to run a little small anyway. Hopefully in the next year or two I'll be upgrading the rear axle to take care of any potential week links.
When are you starting on your swap?
Another great build you have going man, when you mention upgrading the rear axle do you mean going full float? Or do you mean upgrading to a different axle/housing entirely?
Nathan
Sounds like a good plan.
I should be starting here in the next couple weeks, mainly just waiting for the coilovers to be built and sent from California
Nathan
Both have crossed my mind and I'm not sure at this point. It's possible I'll run a 9" rear to help match the full width I have up front but then again its just so easy to keep the rear I have now. I don't anticipate going any bigger than 37's so I don't see myself doing 1 tons but I guess we'll see.
Awesome I looking forward to watching the build. Nice to see all these SAS 3rd gens getting built.
Couple updates. After my shake down run to Superlift ORV I looked over the truck real good and for the most part everything looked great except for my front drive shaft. The shaft itself held up great but the crossmember wasn't nearly dropped out enough to clear the shaft therefore the driveshaft was being cut up pretty good every time the axle dropped out far enough. So I had to redesign my front crossmember a little.
image_zps5dafc965.jpg~original
image_zps4591eaf1.jpg~original
image_zps84aff37e.jpg~original
image_zps1eb708a0.jpg~original
image_zps3b3ad83e.jpg~original
image_zps492b2979.jpg~original
image_zps714ba141.jpg~original
image_zpsfad86c61.jpg~original
image_zpsb49089a5.jpg~original
I like the radiator skid!
But to me the vertical plates on that cross member seem like they should be boxed or have some gussets on them
That's what I was thinking too. Any sort of side load or coming down on one half of the cross member, and I can see that getting pretty bent up.
Problem is I wanted this to be a bolt on skid so later down the road if I have an issue with this radiator I could drop a shorter tacoma radiator in it and ditched skid. With it being a bolt on skid there's no room for gussets on the outside where it bolts up. And there's no room inside the skid for gussets because of the radiator. It's hard to tell in the pictures but I actually made the skid so that the sides are under the frame rails therefore if I took a hit straight from the bottom or front the weight would be distributed through to the frame through the bottom of the side plates and through the bolt on portions of the skid. Not sure any of that made since but i tried lol.
Couple more pics of the skid mounted
image_zps109b17d1.jpg~original
image_zps589e0611.jpg~original
image_zps9b3fd5ec.jpg~original
image_zps7fc3c0e1.jpg~original
I think they are referring to the transmission crossmember.
Well now that you put it that way I'm an idiot hahaha
So let me explain my reasoning behind how I built the crossmember and why I didn't/couldn't really brace anymore than I did. For obvious reasons I wanted the crossmember to remain bolt in. If you take a look at the picture below (I know it's a little hard to see) on the left I couldn't brace simply because if I did the crossmember wouldn't bolt up. And on the right I could have added a very small brace to each side of the plate but really not big enough to have much effect if any it's just too close to the tranny to add in a good solid brace. I also knew when building this that I had plans for a skid plate and that the skid would add more strength to the crossmember when bolted on. My next post will have pictures of the skid plate build.
Well with the SAS done I really needed some protection for the trans pan and T-case so here is what I cam up with.
Started with a peace of 3/16 plate
image_zpsa0430647.jpg~original
Notched it for the drive shaft
image_zps0207b208.jpg~original
image_zpsb7f37d6c.jpg~original
image_zps356ba05c.jpg~original
image_zps09960530.jpg~original
image_zps44b15268.jpg~original
Folded the edges, added some angle, and got my holes drilled for bolts. Tuff thing about this was trying to figure out how to brace the front of the skid being that it doesn't have anything to bolt to in front of the crossmember. This is what I came up with.
image_zps9d102d43.jpg~original
image_zps9b16a817.jpg~original
Then added a small peace that will bolt to the passenger side frame up front and braced it as far over as possibly without getting too close to the trans pan.
image_zps3e194ca0.jpg~original
image_zps52395e7f.jpg~original
image_zps45dcabf9.jpg~original
image_zps47f6c7e0.jpg~original
Good penetration?
image_zpsd4d4671d.jpg~original
Painted
image_zpsabe3c94c.jpg~original
image_zpsac583f9d.jpg~original
image_zps531ab970.jpg~original
image_zps8be70eac.jpg~original
image_zps2d1a048a.jpg~original
Also for those who are interested I went back and updated some of the SAS pictures with a little bit of description.
Also have two more small updates sorry for the crappy pics
10oz of 6mm .12G Airsoft pellets balance the 37's perfect. So far I have no wobble or vibes up to 70MPH (havent' gotten any faster than that but I don't anticipate it being an issue)
I looked at a couple tire options when switching to 37's but at the end of the day I got a great deal on a set of brand new BFG KM2's that I know I'll be happy with. New frame height with 37's and 30PSI per tire is 22.5" from bottom of frame to ground.
Once I got the 37's on it was pretty obvious I'd be needing to either need to start cutting out the rear fenders or I'd need to extend my bump stops a little. Well instead of spending who knows how many hours cutting out the rear fenders I opted to just add about an 1" or so of bump. My old bump stops were rather nasty looking but I couldn't see spending extra money to extend the bumps so I looked around the garage and found a few things I thought would do the trick. Still don't look beautiful by any means but they get the job done and overall don't look too bad. I also made sure they were still bolt on so that I could easily take them off and change them if I wanted to.
Took it down the street to make sure I wouldn't have any clearance issues at full flex
Alright my speedo worked fine for the first 500-600 miles of the swap and now it's dead. I guess I'll need to get a taco VSS to fix the issue?
chasebradshaw
