ADH8796 4runner Build
When that nasty Eaton E-locker breaks and you order an ARB I will hook you up!
:rockon:
Yeah this one is really old back before when it was actually called a Detroit electric locker. I guess later on they become eaton e-lockers. I'm thinking it should hold up just fine but in the case that it doesn't I'll take you up on that ARB deal.
Yeah I had seen his build a couple years ago and wasn't impressed with the amount of flex he got out of it. But looking at it now I can see several limiting factors his setup has that mine will not.
This is the stock ford radius arm I will be modifying
These arms are pretty short and mount to a simple bushing that allows for flex. I plan to lengthen them using some DOM tube and run Ballistic joints. Lengthening the arms and adding ballistic joints will greatly improve the amount of flex I can get out of this system. Pictures below show what I plan to do to lengthen the arms.
You mentioned you're doing leafs but then why do you have ORI's on the list? For the back? Looks to be a sweet build and one for all of us at home guys with like you said "little knowledge and tools" to get ideas from.
Alright I guess it's time I actually update this. Over the past couple months I've been thinking more and more about what route I wanted to go when SASing my 4runner. It seems everyone is pretty wrapped up with either using leaf springs (because they are easy) or 3 link (because it's far superior offroad).
After many hours of searching and reading I finally made a decision. I'm NOT going to use leafs because I won't be able to keep it as low as I want and still run high steer (although it would be considerably easy to setup). I also decided I'm NOT going to run a 3 link setup. I made this decision because I'll be doing this swap in my garage with very basic tools and very little knowledge on setting up a 3 link to make it work correctly. I considered the all pro 3 link setup but most who have traveled down that road have had far more trouble than I cared to experience.
With all that being said I've decided to run a modified ford radius arm setup. It will be very simple to setup and will net me plenty of flex off road while also offering me better road manners than a 3 link setup. I've started to collect parts and hope to start the swap at the end of September or the beginning of October.
Read through the above again. I think you must have miss read something.
Got ya. It was super late and I was reading on my phone. Nice, glad you aren't going with leafs afterall. I've heard great things from Jerry at BAMF about the ORI's. Saw them in action a bit at the last mod day and I'm very impressed. He is taking them out on his first run today so I'll post his impressions on here if you want.
Yeah that'd be great. I have a feeling I'll be very happy with them.
Few more things showed up yesterday.
12" ORI's
And Coilover upper mounts
The rest of my parts should be here end of next week.
SAS pics
BF6B59C1-0B58-47A0-BCE2-126CE01240B8-573-0000009250434823_zpsc2a6a53d.jpg~original
1AFD0275-96CE-453B-8163-1EFDEC003C92-573-0000009623FC4A5B_zpsb8f3a2fb.jpg~original
Ballistic 3.0 joint
7C11A2A1-AB55-42A8-A74F-CE3A942CB2C4-573-00000095B4FE8A2D_zps8c5713fe.jpg~original
For my radius arms I used 2" .250 wall DOM. It's definetly overkill for my rig but I can almost guaranty I'll never bend it. In this pic all I've done is cut down the original radius arm and made a large cut on each side of the DOM so I could slide it over the original radius arm peace.
161FDC40-0665-40E2-A198-77B25D11F842-573-0000009708E3D138_zpsc4b6568e.jpg~original
Trac bar brackets from ruff stuff
53BBBE9E-FF69-48D9-AA3D-889411EE16C3-573-000000973958DCAE_zps147bbc6b.jpg~original
Ballistic heavy duty brackets for the 3.0 ballistic joints and lower coilovers mounts pre cut for dana 44
C15859C8-885C-4D5F-9783-F5C1A1BCFABE-573-0000009785D1BE79_zps819789a6.jpg~original
GM 1 ton steering ends
492B19FA-3DDE-4EEA-A5A6-6BD3D9B13D51-573-0000009803956864_zpsf0aa8731.jpg~original
And a better view of the DOM slid over the end of the radius arm.
BC1EA276-79FB-4D85-9F7B-713E5E0F6603-573-00000098C7EAA112_zps099b82fa.jpg~original
Welding up and plating the radius arms
730C7CAF-C600-4982-82F8-25B3FFF105EB-573-00000098F2BF187A_zps8e9340a6.jpg~original
Finished product without bushings installed
7A764DE3-7DDC-426F-B792-2E9C62CFBA7A-573-0000009956D0CFED_zpsc010ba54.jpg~original
ARB and 5.38's installed. As some of you may remember this axle came with a Detroit electic locker that I planned to run. Well a few days before I planned to begin the swap we went to setup the gears and found out the carrier was for 3.73 and down. Sucked but I didn't have much for options so I ordered what I wanted an ARB and a new SOLID diff cover.
77E216C5-1351-4499-BADB-56B19AC48533-573-0000009986A0BAF0_zps2d885d06.jpg~original
72C78F9A-3F11-47BA-BF46-BBC09C66F709-573-0000009B19F8CCCD_zpsd2fba183.jpg~original
480DA9E3-1E3D-4A11-9524-FB2CD0FCA204-573-0000009B3D519337_zps9e76afe7.jpg~original
5AEC1F3D-9F62-46BA-A384-2833CB03FB11-573-0000009B5B7F091F_zps0b9f7541.jpg~original
This is essentially what I called day 1 pill it in the garage get a couple measurements and get to cutting.
04530C4E-465E-4C65-82F9-F781F0A2B0B3-573-0000009B6F42F3E9_zps59b446ef.jpg~original
Helpful hint when doing my SAS I chose to make a small cut behind the peace still attached to the frame and then with an air hammer and correct bit you can make pretty quick work of getting the frame cleaned up.
D665EB62-842C-4B7F-930D-530E30C38B17-573-0000009B8BADBA66_zpsdea6ff53.jpg~original
B343C943-CEA3-402F-9798-8B727147A453-573-0000009BB94E9E4A_zps27c53597.jpg~original
83A654CD-8061-4F13-A2C7-A8E8243959C5-573-0000009BCBF707BF_zps1060f3f4.jpg~original
9D9E1CAB-71E3-49FA-8138-1ABDD20EBD15-573-0000009C05A02348_zps566a5178.jpg~original
196CE9B7-74A3-42DB-9602-10AABAD34990-573-0000009C3504D55A_zpsadc8c272.jpg~original
This was officially the end of day one.
A39EC4E9-BE56-490F-B967-0B912BC7D6C4-573-0000009C6033F965_zps34b88ea1.jpg~original
I ordered my steering joints but didn't realize they were both wring until it was too late so I had to fab them both.
FAB4E8B7-0DF8-4418-9755-FCB27398E5EA-573-0000009C9AE5633A_zps3e5dc9c5.jpg~original
9A8E39A9-0DC1-4833-A928-D35D543C8344-573-0000009D10A0A7E8_zpsaf2469a2.jpg~original
637AFC22-8286-4FC3-B671-DD317801E780-573-0000009D27DDE78E_zps43b955a3.jpg~original
FA3A56EF-38A0-4353-8F1E-210A3DE0F83F-573-0000009D39F5611F_zps86b0203f.jpg~original
91245BE8-5873-4B40-9976-89ABE0E5DD59-573-0000009D88646DD5_zpsbde4ddc9.jpg~original
19372465-ECB7-4D01-BF5A-AF61E9AE5A8D-573-0000009D99E72D07_zps77e1a9b6.jpg~original
49A79922-BB29-4C19-AC1A-F7B7F2CCA202-573-0000009DAA210BBA_zpsdade95aa.jpg~original
6B7621B7-9D72-41D6-858F-6D13C2A1989C-573-0000009DB7C1AC20_zps540b4c1c.jpg~original
61B781AB-3AED-4364-AE7D-B0DE68CDF5EB-573-0000009E29E1B063_zps17f225bd.jpg~original
Frame plates and shock towers tacked in place. The shock towers didn't fit the frame rails at all. But a little trimming cheer and there along the bottom and it all worked just fine.
02ABC60D-1A1C-4828-9064-1F7201D1B31D-573-0000009E7D3849A7_zps38653b5d.jpg~original
577720F8-66F3-4DBE-A0EA-FDA020966918-573-0000009EA9FF24B3_zps7eef2dc0.jpg~original
Had to notch out the drivers side tower to fit the steering shaft.
4805BC87-D10B-433D-98CE-6F846D7C43DF-573-0000009F0128FB8D_zps2e7be0d6.jpg~original
25A816AA-C1A9-4B0A-8EDE-E41FA9981E54-573-000000A03D8E8EC0_zpsa2980e15.jpg~original
Steering boxe mocked up
89A77278-36A8-4E37-9EDA-3E9F73D89235-573-000000A05242017D_zps5302c40b.jpg~original
AB5B32CD-5E92-4EE5-9A21-52B179E8F1B2-573-000000A066E7260D_zps8a30ffea.jpg~original
8030BAFB-AE38-4D22-812C-FC91C895246F-573-000000A0F086FACD_zps6593ca0a.jpg~original
To brace the the radius arm mounts I used some 2x2 square tube I had laying around.
27BDCE87-52AD-4252-A006-FB22E22DDC50-573-000000A0D92A3479_zps6275f24d.jpg~original
Didn't get any pics of the process but I don't have a tube bender and even if I did I don't think it would have bent the 2" .250 very we'll. So we figured we would have to cut a couple relief cuts in the tube to get the bend we needed. We made 3 cuts on one side and two on the other and even yet we still had to drive a tacoma up on top of the tube to get it to bend.
ACDC988B-167C-4EB5-A383-538AA47C0FAA-573-000000A10A3405A9_zps460ee309.jpg~original
Here you can see the bend we added
FEB00AA8-E22F-411E-86E6-59AD3B76BC8B-573-000000A141402563_zpse04d3497.jpg~original
0CE1EFB2-FBE2-4067-8637-7A7C55996305-573-000000A1E297EC3F_zpsc420343a.jpg~original
The lower mounts were a little taller than I wanted so I marked, cut and re drilled them.
5679E86B-3AEF-4A31-9804-B21D9FF0BE04-573-000000A1939CCDE2_zpsfa4dfa64.jpg~original
Steering clearance.
24198217-5F97-481D-B110-8EAF8ED399C3-573-000000A1C420DAB9_zps6408920a.jpg~original
C2F3C2AA-F7CE-4DB0-B172-4CDCC833B46F-573-000000A20CC20FBC_zpsccd798b0.jpg~original
Tie rod clearance of oil pan at full bump
16AD8B9C-A657-4F23-83DB-173FA4740364-573-000000A25C6723E2_zps12c1dab1.jpg~original
Trac bar angle at ride height.
E8878DDE-EFFA-43A4-A8AD-A2DE38ABCFAB-573-000000A27C35AD74_zps20cebe8c.jpg~original
10383FDD-4F88-4CA3-BA96-5D10E3F21EFC-573-000000A28B61D87B_zpsc88ff42d.jpg~original
06A1F77E-8C67-48DF-ACC6-2D1B7EF3B990-573-000000A29D0E2E9A_zps3719f38e.jpg~original
889666BB-B230-431C-B8DA-B823BFCFA68B-573-000000A2B0A04D5B_zps6b35f220.jpg~original
4E326636-2485-4724-B1B8-54F1FC49ACC1-573-000000A2CA6C8E13_zpsc845688f.jpg~original
E2C81B60-C58E-475A-9382-E6DF6BF0C339-573-000000A2E200132D_zpsa46ce2bd.jpg~original
1A04CFEC-7776-4217-A094-BB77773F9E17-573-000000A2ED774EA6_zpse6161741.jpg~original
2D22BD22-CABD-4B89-847A-B22542C327AE-573-000000A30079B3AC_zpse542623e.jpg~original
70B634C7-625C-40D0-B66D-9FAEC02ED566-573-000000A312D3F527_zps08f229d4.jpg~original
AF6FF19E-AE66-4A1D-B500-8374F7805058-573-000000A322E38308_zps042e2d31.jpg~original
8BDBD920-0CBD-4259-BCA2-A6041E9BF690-573-000000A341D4B08E_zps0019f63a.jpg~original
This was a huge pain in the ass and took a large amount of time to do it correctly but I didn't really have a choice on my deadline. Being that this part is so extremely important I wanted it to be done correctly but it would been great no to have to waste all the fab time on something that should have been plug and play.
6C0F179D-7472-484B-A619-2473091A2920-573-000000A3806DF484_zpsa1d1c610.jpg~original
F763D8F9-2DE0-42C2-9E0E-FCE80A766D26-573-000000A3BBAE2B9F_zps53bd96de.jpg~original
B039F7C0-5A4E-489E-B54B-EF933F073338-573-000000A3E2C9271C_zps8bc00d71.jpg~original
Trac bar cut and tacked, trac bar mounts tacked in and a pic of trac bar angle at ride height.
6D4198D0-56B0-4CA0-88DC-EC782A63AD33-573-000000A443E4F761_zpsabe61c4f.jpg~original
Had to cut and re-plate the front crossmember to clear the radius arms.
5FBD4436-404C-4A32-A3CE-EEE9DF3B2AE5-573-000000A454B6EBDF_zpsa8cfc0c5.jpg~original
36F73DA1-930F-48D1-ADBA-88976A34C771-573-000000A47F8C618F_zps67a912ac.jpg~original
Welded up the relief cuts in the radius arm and smoothed everything out.
B34FB624-B802-475E-96B9-B3A210C5DC86-573-000000A4B42F9DB1_zpsafe8f131.jpg~original
D015D55D-64C6-4D57-B955-20E5B6951E8D-573-000000A4CBE40B82_zps3d5fa5e0.jpg~original
Now I really don't think this was necessary but It was good for my peace of mind. I took some old tube cut it in half and molded it to the radius arm then welded it up for extra strength. Like I said I don't think this was needed but at least with this done I'll never worry about it being a potential weak link.
F41FA5DA-C688-4B90-BE02-1052C8165740-573-000000A4D76E3A0F_zpsf78fc865.jpg~original
BF989D17-1221-4484-B5FE-D994BB597A37-573-000000A4E28871CA_zpsf00c2674.jpg~original
Cut a couple peaches to help brace the lower mounts.
E52164E1-2CF4-4A6A-8FFA-E75811B61FE1-573-000000A4EFDACCF5_zps8f0b38cf.jpg~original
Welded in the bungs
E799D6C8-BC94-4B83-B783-78F04293C8B5-573-000000A502E79791_zps213ebbfa.jpg~original
Chopped the crossmember for driveshaft clearance.
EF44D6EE-990E-4230-920C-EA55CDF38C1C-573-000000A5156A9A4C_zpsfb552314.jpg~original
C5A12ED4-2646-4337-BC6A-DD624255F1C5-573-000000A5520DDF1B_zps25c1579b.jpg~original
27D8439F-84B1-4218-AEB6-4E61F2B0E6B0-573-000000A55FED8CAC_zps2fd45880.jpg~original
11096116-9B03-427B-ACAA-F704915442CD-573-000000A56DA1B39A_zps2f84aeb3.jpg~original
C0991DD2-CE6B-4423-B806-5A296A195F8E-573-000000A59A98527B_zpsd7d90bf4.jpg~original
And then I spent the next 6-8hrs welding everything in solid. It's hard to stay focused after a while.
CC1975D1-AEFC-4F62-860D-0B3CE39DF7A2-573-000000A5F29BE3CD_zps507c9042.jpg~original
44B7BB50-A121-42E5-94F3-E28D29E13F1D-573-000000A5E5DBAC64_zps1640379a.jpg~original
Wasn't sure what I was going to do with the brake lines but it turned out a hole drilled through the tower and a clip on the back side worked perfect to secure everything in place.
Frame height ended up at 21 7/8" and I'm now runner LC80 coils in the rear instead of OME 891's.
I started this build on Friday the 4th at 9:30am and finished the build on Friday the 11th at 7:30pm. Packed up my stuff and headed to Superlift ORV in Hot Springs, AR 400 mile round trip for the Souther Cruiser Crawl and had a blast. Ran a lot of very technical trails and was still able to drive home at 75mph with ease.
1AF8531B-F3D3-4A6F-9308-42A43A6343EE-573-000000A6B5B71C93_zps69103e74.jpg~original
F5EC42B8-04E2-4FE3-88ED-35B923E0DA99-573-000000A6FC87FBB2_zps9963b354.jpg~original
41EEE668-C26E-446A-8BDB-C31CD6956FED-573-000000A7260421C7_zps029dd50a.jpg~original
3B812A0D-710E-4D60-87F5-C9BE739DF59F-573-000000A73B4AEA3E_zpsbda9d639.jpg~original
03F26EBB-C221-405F-83E2-C416EDFB3B66-573-000000A7689021AC_zps3bbe228e.jpg~original
8A686699-8916-4CD0-A147-674D04B833EE-573-000000A77991350D_zpsf00122cb.jpg~original
B4E5046B-454E-4518-9457-52436356183A-573-000000A7A4B9FFB2_zps2b194e22.jpg~original
32345191-F61A-4A51-B7C6-005EAE035E38-573-000000A7BE09C986_zps00895f99.jpg~original
1C9E1595-238B-489A-A724-7E4D1651D43A-573-000000A7CF164272_zps9db9841b.jpg~original
21A3E369-062E-4B6F-AA17-69E5CA9B260B-573-000000A7D3861F27_zps38cadcea.jpg~original
D07D9FA8-4C3C-4F03-BA5F-9E5E0F0B0AAD-573-000000A7D90D2623_zps3b0fcf5d.jpg~original
CA7BF74E-0E25-4B28-B65C-D83780C01F5E-573-000000A7DE70CFA2_zps0c1fe18c.jpg~original
E81F16E3-3587-420D-8A53-F9091C7F209A-573-000000A7F66D48BB_zps0d054966.jpg~original
E2643998-DB41-476D-B799-61997C5E23D6-573-000000A7FAFDFD9F_zps93f21e5c.jpg~original
seltzernator
