ADH8796 4runner Build
I took a look at this chart to determine roughly how many ounces I needed per tire Aggressive Tire Chart this chart is specifically for Dyna beads but should work just fine for air soft apllication as well. The chart recommends 8oz per tire but adding more than you need won't hurt anything unlike not having enough.
I'll be sure to follow up with a review on how well they work.
X2 I've looked into these before as well. Great start! Can't wait to see it finished!
Great start to the build. This will be a sweet addition to the list of runners you've built. looking forward to it.
sam
Also forgot to mention I put in some weathertech digital fit floor liners. I've had them in every vehicle I've owned for the past few years and while they are expensive I personally feel they are well worth it.
Well the stock head unit wasn't going to cut it so I picked up a Pioneer P3400BH off amazon. I did some reading on different unit's and this one had great reviews and was capable of performing everything I wanted it too and more. Along with the P3400BH I ordered a backup camera and the override so I could use all functions even while driving. And last but not least a ScangaugeII to help keep up with tranny temp and all the other fun stuff it tells you.
IMG_2426.jpg~original
IMG_2498.jpg~original
IMG_2497.jpg~original
While I had all that going in I decided to toss in an old amp and sub I've had sitting in the garage for a couple years.
Bad picture of the rear cargo area with to sub tossed in
IMG_2434.jpg~original
Mocking up the amp under the drivers seat
IMG_2432.jpg~original
I really didn't like the mount for the license back up camera. It's bulky and weird looking. So looked at a bunch of options to help hide the camera but for it to still be functional. I was able to keep everything very clean and wires were run through factory holes. This is what I came up with.
IMG_2571.jpg~original
IMG_2572.jpg~original
IMG_2573.jpg~original
IMG_2574.jpg~original
IMG_2576.jpg~original
IMG_2577.jpg~original
IMG_2579.jpg~original
IMG_2581.jpg~original
IMG_2585.jpg~original
Finally got around to pulling the sticker off the back hatch and painting the faded spoiler.
IMG_2683.jpg~original
Had a check engine light pop up will running down the road so I checked it with the ScangaugeII pulled up as P1135 A/F sensor. So I ordered the Denso replacement from amazon. Very quick and easy install and so far no more codes.
IMG_2621.jpg~original
New and old
IMG_2622.jpg~original
Alright it's time I finally got caught up on this build thread so here it goes...
In the past I've always had round tube sliders but this time I was looking for something different. After looking around a some different options I decided I'd just start out with square tube 2x2 3/16". I saw this setup on a few old Branco's and just thought it looked clean, simple, functional and easy to add onto in the future if needed i.e (kickout's or angled round tube). After looking around at a few builds here I saw Dirtco had put together a set I really liked. So I went and bought about $62 worth of tube and got to work. I had a few 3/16" plates left over from a previous bumper build so that's what I used for my frame plates and end caps.
IMG_2526.jpg~original
IMG_2527.jpg~original
4x4 Frame plates
IMG_2528.jpg~original
After looking good and hard at how long I wanted the sliders I decided on 63". At this length they should provide plenty of protection and leave plenty of room for 35's.
IMG_2536.jpg~original
IMG_2535.jpg~original
IMG_2534.jpg~original
End caps traced out
IMG_2537.jpg~original
IMG_2532.jpg~original
And legs cut down
IMG_2538.jpg~original
IMG_2542.jpg~original
Caps cut and placed in the tube
IMG_2544.jpg~original
Welded and smoothed
IMG_2560.jpg~original
IMG_2561.jpg~original
Prepping the frame
IMG_2556.jpg~original
Plates welded in
IMG_2557.jpg~original
Thanks to Dirtco's writeup on his sliders I already knew I would want to fill in the gap between the tube and the body so it didn't look funny. But the only thing I had was 3/16" plate and that just seemed like a lot of added weight for something purely cosmetic. So instead I decided to look at what I had laying around and see what I could come up with. I ended up taking the plastic off of my stock running boards and using it as a filler.
IMG_2586.jpg~original
It ended up being the perfect length and kind of gave it a little more of a factory look.
IMG_2595.jpg~original
I wanted my sliders to stick out far enough that I felt I had a little bit of tree protection without it looking funny. However I also wanted it to be tucked as far up to the rocker panels as possible. So I decided to notch out the pinch weld were the legs would be. It doesn't see like much but it made a big difference in where the sliders ended up.
IMG_2600.jpg~original
Welded the legs in place (flux core no gas)
IMG_2602.jpg~original
IMG_2610.jpg~original
To attach the plastic to the sliders I used 9 self tapping metal screws.
IMG_2639.jpg~original
IMG_2640.jpg~original
Then for a little paint
IMG_2646.jpg~original
IMG_2645.jpg~original
IMG_2653.jpg~original
After letting the paint sit overnight I welded the sliders on
IMG_2649.jpg~original
IMG_2678.jpg~original
IMG_2679.jpg~original
IMG_2681.jpg~original
IMG_2682.jpg~original
IMG_2684.jpg~original
IMG_2685.jpg~original
Ordered built 3rd's front and rear from ECGS 5.29's and ARB's and I have nothing but great things to say about their customer service and super fast shipping.
IMG_2590.jpg~original
IMG_2589.jpg~original
IMG_2626.jpg~original
IMG_2625.jpg~original
I wanted the ability to to fill tires if needed so I peace'd this together this from home depot it's simple and it works.
IMG_2618.jpg~original
And then tossed in the 3rd's
IMG_2634.jpg~original
IMG_2638.jpg~original
Today was Thanksgiving but since I was stuck at work we played a little and then I got a few more things finished up
IMG_2612.jpg~original
Compressor mounted up and switches installed
IMG_2630.jpg~original
IMG_2680.jpg~original
That's it for now. Hopefully my wheels will show up before too long and I'll be able to get the lift and everything mounted up so I can start on bumpers.
Sick build! You have some pretty good attention to detail - love the sliders, and the running board plastic addition, looks good!
All in all, some pretty sick rides there! Welcome back, looking forward to following this thread!
Awesome work, I like your style! I looked through your old build thread several times when I was building my 4Runner, it's kind of like deja vu (Black 3rd Gen, Black 3rd Gen, Black 3rd Gen; I think I'm starting to see a pattern :)).
What wheels did you order? I really wish I would have gone with the Raceline Monster's instead of the Trail Ready HD beadlocks.
Thanks man!
Thanks man I've followed your last two builds and you do great work. Very clean and very functional.
Kind of a long story. I ordered the Raceline Monster RT 233's (polished with black ring) in a 17x8.5. After a week I finally called to see if they had shipped and it turns out they only had 3 left in stock. So I asked how long it would be before they would have a 4th and they said it would be right around 6 to 9 months. Apparently the mold for that particular wheel is having to be reconstructed and won't be completed for the next 6 to 9 months. So after talking to them for a while longer he mentioned he still had a few RT 231's in that size as well (same wheel but powder coated black). He said they could send off a couple 233's and get them powder coated to make them 231's. He also said he could get me whatever wheel I wanted in a 17x9.5 but I really think that's just too wide for a 12.50. So after looking around at other options I decided I still wanted to go with Raceline and gave them the go ahead to send off the wheels to get powder coated. Two weeks later I heard they had only sent off two wheels not all four so when they got back I had two shades of black on the wheels. So they had to send them off to get stripped and re-powdercoated :bash: Anyway as of now they still haven't been shipped but come monday I should know when to expect them at my door.
Decided to go with the aluminum polished ring mostly because unlike the black steel ring it protects the bolt heads.
IMG_2396.png~original
Got a call from Raceline today and my wheels are officially on their way. Should be here on Wednesday next week. But in the mean time I got a few things done.
In an effort to maximize my stock rocker panel switch locations I built a little panel out of old plastic and sheet metal I had laying around the garage. This leaves one spot for driving/fog lights. I got this idea when I was looking through ARKRWLR's build and saw the rocker switch panel he bought from Otrattw.com
IMG_2757.jpg~original
Also pick up a DieHard Platinum marine battery. The factory battery mount wouldn't fit so I fabbed one up real quick.
IMG_2752.jpg~original
Picked up a 25ft air hose from harbor freight for $5 for topping tires off if needed. Now I just need to pick up a good air chuck that clips on so I don't have to sit and hold it.
IMG_2703.jpg~original
And after a short wait my winch arrived. I was pretty pleased with quality of everything.
IMG_2664-1.jpg~original
IMG_2669-1.jpg~original
IMG_2670-1.jpg~original
IMG_2661-1.jpg~original
IMG_2659-1.jpg~original
IMG_2717.jpg~original
Awesome build, just like your previous ones. That is the same winch that I plan on getting. Let us know what you think of it.
Dang man, you're dropping some cash on that pile of parts! Nice buy on the F/R ARB's & Compressor. How does that thing feel on the stock size tires with 5.29's?
Nice work on the sliders, and I like the switch panel too. :bigok:
I must admit, that front bumper on your old Runner is one of my favorites I've ever seen!
Another awesome built 4Runner on 35's. Creative thinking with using the old running boards for slider fill-plates.
Subscribed.
Thanks! I'll let you know how it goes. I expect good things based off of previous experience with my old smittybilt. This one seems to be much nicer even in the little details.
Yeah I knew it was coming but it still hurt to drop the $$$. Gears feel great even with stock tires around town. Little different on the highway but it will be nice when the 35's go on. At 60 MPH I'm at 2400 RPM makes me wonder how I ever kept stock 4.30's with my last rig. Thanks for the complements.
Subscribed.
Thanks I really do miss that bumper. But I think this go around I'll be moving to tube. Just thought it'd be nice to do something different from past build and I like the idea of saving on weight.
I can't take full credit on the running board idea. I was really wanting to fill the gap but didn't have any good stuff laying around to do it with other than some plate. I was just getting ready to cut what I needed when a buddy of mine suggested just filling it in with plastic and I said that's a good idea but I don't have any plastic. He walked around his shop and saw some old running boards laying on the ground and had the idea I could use the plastic off that. So after looking at them for a while I cam up with what you see. Glad I didn't add 30lbs of metal to what are already pretty hefty sliders.
seltzernator
