Adjustable Endlinks
Sacto4Runner
Looking for some adjustable endlinks to drop the front sway bar to keep it out of my new coil overs. Even with the SAW adapters that relocate the sway bar, they still make minor contact with the coil overs. Been searching the forum for a while now but coming up empty. Any ideas?
im sure you could have a set fabricated quite easily.. wab fab maybe?
potentially stupid questions... are you sure everything is installed correctly? did you have to put spacers on the lower shock mount? is the charge port facing outward?
Yeah, double and triple checked. Port is facing outward. When I checked the lower adapters on either side of the heim joint with the dial calipers during intallation, they mic'd out the same dimension. I saw no signifigance in the instruction to place the larger forward - they were identical. Minor rubbing, not audible. Just seems if SAW went to the trouble of machining the adapters for the sway bar, the coil-overs should clear the sway bar...
you may want to contact member webe363 who just installed saw 2.5's recently.
if it is a minor issue, you can install an FJ sway bar which is 1mm smaller in diameter. it will be better off road as well, allowing more compliance over obstacles with no noticeable on-road change
I believe all pro offroad recently came out with some but it might be under the fj section. The fj uses the same setup.
All-Pro and a few others have some,
They have mostly FJ stuff listed , But it's the same.
They are much stonger also , I guess they break (stockers) and pop the CV boot .
