Advice on eliminating rake, lifted
Rocket61
Hey guys so my ome/5100 suspension has been on for about 20k now and things have settled down. This weekend I installed a 1.5'' spacer on my rear drivers side to correct the lean. Now the rear sits perfectly levelled at 39'' from the ground to the top of the wheel well. The front has also settled a bit and now after that rear spacer it's sitting 1.5'' lower than the rear, with both sides at 37.5''. The front drivers has had a .25'' spacer since the suspension was installed. So what do you guys thing? How can I bring my front up? Add spacers? If so which thickness? Crank up my 5100s by one or two notches? They're at the lowest setting. Any advice would really be appreciated!
Raise your billy's up one notch. That will give you 0.85 inches of additional lift up front. See this post for lots more info.
I really like the guy who made that post. :typing: ;-)
Jhunt
