Thai
Elite Member
Advice:
Things that can go wrong in Winter, and why..
by Phil Bailey
Air Filters
Air filters are the single biggest villain when a fuel injected car won't start on a cold morning!
Your gas pedal actually no longer controls fuel supply, so stepping on the gas pedal these days is a myth. Your computer controls fuel flow by varying the fuel pressure at the injectors, or the opening and closing of the fuel valves. All you control with the right pedal is how much air is getting into the engine.
If your air filter is dirty, then the throttle positioning sensor will call for more fuel supply when in fact it is not needed. Eventually, other sensors will detect the lack of air and illuminate the engine warning light. But by this time, you may well have been towed to a garage with a flooded engine and have had to have your spark plugs changed as well as a drying out of the combustion chambers with compressed air. So a twenty dollar air filter is a good investment in trouble free cold weather starting.
In extremely wet conditions, with the temperature hovering around the freezing point, an air filter can actually get wet and then ice up. Parked overnight, the dampness turns to a thin layer of ice and the filter is blocked solid. In these conditions, parking indoors whenever possible is a very, very good idea.
Heaters
As autumn approaches, everyone is starting to turn on their heater and there are a few things to watch for. If your heater does not seem to be giving good performance, it could be that the controls are stuck in the cooling mode and will need to be readjusted. Many systems rely on vacuum operated plastic flap valves under the dashboard and during the summer you may not notice that a little bit of fresh cold air is entering the car, but now you will feel a lack of heat and these controls need to be checked.
Radiator cap
A bad radiator cap can also cause your heater to under perform and it is a very simple job to verify that this cheap but essential item is holding pressure. Your thermostat should be checked to make sure it is opening and closing at the right temperatures. If it has stuck open, it will not show up so much during the summer, but a failure to heat up quickly in the fall can damage your engine as well as leaving you with cold feet.
A few minutes at your garage is all that is needed to check these items and make sure you heater works well all winter.
Rear defroster
If your rear defroster isn't working, does it mean you have to replace the glass? No, there are several possibilities. First, if the conducting elements themselves are broken, they can be repaired using a special paint. Very often, we find that the side connections are corroded or broken, which is not a large task to repair. Sometimes the defroster switch itself is defective, even if it lights up, but a quick check with a multimeter can pinpoint this problem.
So don't despair if your rear defroster doesn't work, most likely it can be repaired at quite low cost. You can extend the life of your defroster by turning it off as soon as it has done it's job. Leaving it on for long periods can burn it out and also puts a big load on your charging system. Cleaning the snow off your back window before you drive away, gives your defroster a better chance to work quickly.
Battery
It's time to think about your battery which powers your on-board computer. On the cold mornings of autumn it will be tested more than it has been all summer. If it is more than five years old, most likely it is about to expire. A battery giving low voltage under load can seriously affect the way in which your computer processes information. It's a bit like trying to run your PC on 90 volts - some very weird things can happen.
So when you start your car on a cold morning, the fact that your engine doesn't run well may be nothing more than a lack of voltage to feed the computer. A good battery is absolutely essential to operate the space age systems we are all carrying around in our cars. A good alternator can compensate for a while, but eventually it will also start to let you down, since it will be constantly overloaded. Both these items are very easy to check, using a special loading device at your local garage.
Engine oil
I know that the use of synthetic engine lubricant has been discussed in these pages quite extensively in recent months, but it's worth repeating that if you've never tried synthetic engine lubricant, now is a good time to start. Synthetics last much longer than ordinary oil; give very superior cold start protection by providing upper engine lubrication before oil pressure reaches normal values; flow very easily; maintain their strength when they are hot; are not easily weakened by fuel contamination and will reject the effects of by-products of combustion.
North America uses up to three billion litres of engine oil every year, a good proportion of which disappears into the environment. A switch to synthetics will help your battery last longer, protect your engine and reduce the amount of waste oil to be disposed of. Remember the colour of your oil is not an indication of it's condition. All oils turn dark brown very quickly.
Autumn leaves
Autumn leaves may look nice, but they can cause some problems with your car. Many cars are vulnerable to the debris that falls from trees, because it tends to block off the air intake to your ventilation system. Even if your heater is in fine working condition, no air flow means no heating and even a small deterioration in the amount of air coming into the car can make a huge difference to the total amount of heat available. Cleaning out a system can be quite tricky, time consuming and expensive if a garage has to do it, so that clearing the leaves from your car before you start the heater fan can help prevent blockage of the air intake and in the long run can save you quite a lot of money.
Driving away and allowing the wind to do the job is not a good idea, because even if the fan is not running, natural air flow will cause the same entry of leaves into the air passages. So let your car warm up while you clean the leaves off and save yourself some money down the road.
Windshield washers
And although we've covered the subject in recent times, again, it's worth reiterating that it's time to think about your windshield washer system. If you've been using water in your system during the summer now is the time to change over to a good quality minus forty fluid. If the summer fluid freezes, it can damage your windshield washer bottle severely and this is a very expensive item to replace. If the new fluid produces streaking on the windshield, then your wipers may not be up to clearing away such an alcohol-based fluid and most likely they will need to be replaced. The ones to avoid are the bare steel type, which encourage ice build-up on themselves. If your system uses little pipes that run up to the wipers, you can prevent premature freeze-up in the pipes by fortifying your fluid with methyl hydrate. Add one litre to a regular four litres in a larger container and label it accordingly. Methyl hydrate, otherwise known as wood alcohol, is freely available at your local garage parts and hardware supply stores.
by Phil Bailey
Air Filters
Heaters
Radiator cap
Rear defroster
Battery
Engine oil
Autumn leaves
Windshield washers
