Advise on add system.
Llowlife
Recently bought a 92 4wd. It has some minor mechanical niggles. But I'm pleased as it's a 5 speed, rust free, 3.4l clean truck. In Mn rust free is a search far far away.
Anyway the front diff is connected directly to vacuum so it must be engaged all the time. It works fine when I drop the 4high and low in and the 4wd light lights up. I haven't studied up on the add yet as to it's complete operation but if my understanding is correct it locks the axles together Thereby putting the driveshaft into the picture then waiting for the transfer case to engage the front shaft. There is no wiring going to the front diff sw so someone must have jumpered or disconnected the switch depending on its operation. Without doing so i wouldnot get a 4wd light on the dash.
Basically is it worth buying or making the wire buying the solenoid and installing them or just run her as is. Has anyone noticed how many mpg difference there may be? Just trying to decide if I bother or leave as is since it works.
If my info is incorrect enlighten me please.
it might make 1-2 mpg difference max.
If you don't have the vacuum solenoids or wiring, it may not be worth the effort.
I'm feeling a little bit rusty, trying to follow along. But here's an idea: if everything works for 4HI/4LO, but you want to be able to freewheel, add some locking hubs. Sometimes you can find a set in a wrecking yard for cheap and just rebuild them, or you have to buy them which can be spendy. But that would disconnect the wheels from the CV axles. The drive shaft from the transfer case won't turn until you shift into 4WD, so that would keep your front axle from adding drag to the engine. Not much drag... fourwd1 is right that it isn't much difference in mileage.
...and you have a 3.4 in there? Swapped in? Or is it just the 3.0?
3.4 swap. Some things left out during swap or we're nvr there. Need washer fluid tank and I suppose some stuff I haven't noticed yet. I'm working on buying a 3rd gen if the elocker is 4.30 ratio like this one. Not sure if the 3rd gen had the add. If not then may put a manual 3way control valve and run it that way. Valve is 5 bucks and a little vacuum line. Time will tell. Found a second gen parts vehicle I may look into if the other diff won't work
Swapped! That's cool! I've toyed with that idea on the older ones I've had.
I'm not an expert on the 3rd gens, so I can't help you there. Good luck!
PRWhite
