Hey everyone. I'm looking to install an aftermarket DC-AC inverter in my 2008 SR5, and I have my mind set on a permanent-mount inverter that is rated @ 750 - 1,000W (so far, I like the Tripp-Lite products). The tricky part is that I'm looking for an elegant install. In my book, this means trying to make use of as many OEM components as possible.
While my truck was not delivered with the Toyota inverter, the engine compartment fuse/relay box clearly has a slots for a fuse and relay allocated to the inverter. What's more, I purchased an OEM "AC 115V" switch from a scrap-yard, and when I plug it into the existing harness (to the left of the steering column), it illuminates. This is a positive sign!
My guess is that the wiring for the inverter may exist throughout the vehicle. That being said, I've read throughout the forum that the Toyota OEM accessory inverter is only rated to ~100W. This would lead me to believe that the OEM wiring, even if in place, is probably way to light a gauge to support 750 - 1,000W of load. Everyone agree?
Given these likely facts, I think my current mission is to try to hack the existing OEM dash switch so that it can control the on/off of a newly hard-wired inverter in the cabin. I'm hoping some more electrically inclined forum members can help me understand the pinout of this switch, and how to use it to implement a relay-controlled circuit for the inverter. I also need some help selecting the relay itself, as it will need to be able to handle a load of up to 2,000W @ 12V (most of the inverters I’ve come across are rated at momentary load that is 2x the continuous wattage rating). As a part of the executing the relay aspect of the install, I also need some help in understanding literally how I pass a 4-6 AWG direct connection to the inverter through a relay such that the connection itself does not create a significant voltage drop.
Any thoughts would be very much appreciated!
