Aftermarket Fog Light Assembly?
swanny
Any links to quality aftermarket fog light assemblies for an 06? Would love to go LED, but haven’t seen anyone that does a mount bracket for the 4th gens.
You can use the Baja Designs Squadron R lights with this Ford/Toyota, F-150, Tundra, Tacoma Fog Light Kit and a little modification.
You have to drill a small extra hole in the plastic of your bumper and reverse the polarity going into your factory harness. Very well worth it, I love mine.
Thanks for the link to the mount. Any chance you have a picture of exactly what needs to be drilled and where from when you (I'm assuming) did an install? Or is it pretty apparent once you take the current ones off and try to mount the new lights?
One of my housings has a bad seal, figure I may as well upgrade if I can
Do you have a picture of what this looks like installed on yours?
[MENTION=114745]YetiX[/MENTION] definitely gets the credit for how I did mine. Followed exactly how he did it and yes, as you're doing it it's apparent what needs to be done. Very easy and the difference is between lights is amazing.
https://www.toyota-4runner.org/2973768-post36.html
Someone has also gotten Diode Dynamics Stage Series 3 fogs into the stock location on our trucks and supposedly DD are making 4th gen specific brackets soon. That's probably what I'm going with once my headlight projector retrofit is done.
Jhunt
