Aftermarket fuel pressure reg
hoe_nah
Anyone have any experience using one with a dial on it? Adjustable id assume or is it not necessary? This is for a 3vze btw
I used them before, but you'll need an adapter. I found it easier to just run and oem Denso unit(see pic).
There is also a fuel pressure dampener on the rail as well. You might consider replacing it as well while in there. It's also a good time to look at the coolant temp sensor for the FI system and injector seals. Happy Holidays.
regards
