Aftermarket Power Steering Lines
RumHam26
I need to replace my steering rack and lines. I'm going OEM for the rack, but am considering going aftermarket for the lines. I am seeing Sunsong, Edelmann, and Gates options on Rock Auto and eBay. Couldn't find much on the forum about quality of aftermarket lines. Does anyone have experience with any of these? Even with the brands in general?
Thanks!
I picked up an aftermarket high pressure line from Rock Auto about 5 years ago, I think it was the Sunsong, no problems so far, also got the return line fitting stub at the rack end. I too just got a OEM Rack as part of my upcoming front end suspension, steering rebuild but plan on reusing the line.
I have had great luck with Gates for timing and accessory belts and hoses, they still manufacture a bunch of stuff in the USA too. Can't speak to the quality of the other brands as I haven't used them that I am aware of.
I bought and installed the Sunsong kit from Rock Auto - they were the only one that had both lines and all the brackets. They fit really well, and they seem to be working fine - no leaks and no whining pump. We'll see how they hold up against corrosion - I will probably keep them coated in fluid film on the metal parts.
Crow-foot tool
In my case the line connections were completely seized at the rack end, literally broke the flare nut wrench in 2. the high pressure line is all 1 continuous mix of flex and hard line no removable fittings.
Use a good quality crawfoot tool with an extension and then a ratchet.
I used a Gates timing belt in my 92 corolla and it started showing cracks around 50K miles. Guess for a pressure hose steering it is not crucial.
Philthyphilthy
