Aftermarket UCA on Mild Lift?
ZiaMan
Member
Tried searching but couldn't find anything. I am going to be installing the Bilstein 6112s at the second ring (~.5" os so lift) on my GX. I figure it's a good time to replace the UCAs while I'm in there and want to order JBA's.
My question is will the improved JBA UCA geometry be too much with a mild lift?
The improved geometry allows for more adjustment but it does not require you use it.
I like the JBA's and may buy a set later this year, post up pictures when you install.
I have a similar concern. With my 6112's, I'm maxed out on caster at 2.2 degrees, and I'd like to hit 4 degrees.
I'm worried that I'll add to much caster and make a unique situation for no reason..
I just finished installing the 6112s on my Runner and my caster went from 2.6 deg to 1.6 deg. I picked the lowest amount of lift and according to Bilstein, you're suppose to use #3 slot on the driver and #1 on the pass. This net me 2" of lift. So I'd like some caster back as well and may have to save up for the JBA UCA units.
charlesz
