aftermarket wheel ?
Gstick
Member
Is there any aftermarket wheel manufacturer that makes a 6 spoke, 17" wheel identical or similar to the 6 spoke, 16" Trail Teams wheel ?
OK, forget the 6 spoke wheel question. I found an aftermarket wheel, and I just want to make sure it will work on my "stock" (no lift) 2010 SR5 4x4. Some questions that I have are :
Can I go 1 tire size taller, and/or 1 size wider than the OEM 265/70 R17 on this new 17" x 8" wheel, with no lift on my 4R?
The aftermarket wheel is a 17" x 8". What is the proper bolt pattern dimension, offset, and backspacing that I need to fit my stock 4R?
Here are the dimensions of the wheel that I want to buy:
6 x 5.5" bolt circle
4.5" backspace
0 offset
108.71 mm centerbore
uses 60 degree conical seat lug nuts
workingwheelswnc
