Air compressor
GEOFF
Any ideas on installing an on board air compressor mounted in engine bay on a 22re 1st gen. Any good brands and models? Whats your guys thoughts?
You can turn your AC compressor into a pump, or get a york compressor.
Are you thinking an electric pump or one that runs off your belt system?
I like the idea of the ac compressor but I like having the ac working. Is there a way to hook up a second ac compressor (from my parts truck) on the 22re in a first gen 4RUNNER?
If you have an AIR pump as part of your emissions system and don't have emissions testing, you could fab some brackets to mount a 2nd AC compressor there.
I will check on that. Here in Ontario emissions testing starts for vehicles starting in 1988, mine is exempt from testing being that it is an '87.
I don't have ac. Any electric powered options? I've seen some jeep air pump pics. Any pics of on a runner?
You can go cheap with a Superflow MV50 as long as you aren't running 35" tires or bigger. Superflow has bigger units for larger tires but I have aired up 33" tires in under a minute each with my MV50, it takes me longer to air down than up. I paid about $75 locally for mine. What I like best about it is it is complete, and portable. Amazon.com: Master Flow MF-1050 Tsunami High Volume Portable Air Compressor: Automotive
If the Superflow doesn't look like something you want you could go with some of the fine VIAR compressors with an onboard tank for that "Pro" look. Right now there are some good deals on VIAR combos here >
Viair Compressors, Viair Compressed Air System, Viair Onboard Air System
